Engine hum
Old Jul 17, 2006 | 06:18 PM
90lxstang's Avatar
90lxstang
Default Engine hum
I've noticed a new noise on my brothers 03 V6 auto. While you'r giving it gas, just cruising, the engine creates this low hum noise. Its only when you give it gas, steady or slamming it gets the same hum results. The only thing I can relate it to is a low-end tone flying saucer, or a cruise boat horn that is constant (just not as loud[8D]). Anyone know what this is and how to fix it? It gets annoying.
Oh..btw, its got 59K miles and never has had a tune-up besides oil and filter. But the works is coming at 60K.
Old Jul 17, 2006 | 11:26 PM
NewMexMustang's Avatar
NewMexMustang
Default RE: Engine hum
could it sound like (sort of) a card on a bicycle wheel but more "airy"[&:]
Old Jul 18, 2006 | 12:41 PM
90lxstang's Avatar
90lxstang
ORIGINAL: NewMexMustang
Nope, nothing like that. Has anyone rode in the back of a pickup truck? It kinda sounds like the extreme tire noise you hear while back there. I was thinking it was just tire noise but it only happens with the gas pedal down.
Old Jul 18, 2006 | 08:04 PM
bullittproof01's Avatar
bullittproof01
its your idle air control valve.
when its jammed, it doesnt open and close properly, which creates that humming noise you hear. if you turn your car on and pop the hood you can easily test it. just go over to that little lever that you can push which revs your engine and give your engine one long rev. it should start humming.
if it does just clean that out with a spray from kragens or whatever is close to your house and let it sit for two minutes before you dispense the cleaner. then let it dry completely and put the control valve back on. should work fine after that. if that doesnt work buy a new valve for 50 bucks. good luck
mtgldr
Feb 3, 2024 09:00 PM
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
