mod path?
Old Jul 18, 2006 | 06:31 PM
nickolas388's Avatar
nickolas388
Default mod path?
ok i have a 2000 mustang v6 stock. i was wondering what modification paths do people usually take. can i run a CAI as a first mod? do i need engine managment to start modding? thats really all i can think of for now.
thanks,
-nick
Old Jul 18, 2006 | 08:54 PM
561boii's Avatar
561boii
Default RE: mod path?
yes juss slap a CAI on there and then exhaust[or vise versa]
UDpulleys
4:10 gears
t lok
and you should be set.
be sure that you get the gears and t lok at the same time because they go to the same place....
561boii's Avatar
561boii
P.S.
and a tuner....then youll be set!
i knew i was forgetting something[&:]
Old Jul 18, 2006 | 11:36 PM
jthorn9's Avatar
jthorn9
The Godfather
Well start with performance mods first, as nothing worse than a stock V6 mustang with a body kit that looks fast, but is slower than caramel.
1.) Cold Air Intake
2.) V6 X pipe/h pipe (your choice) and GT cat backs
3.) Under Drive Pulleys
4.) Handheld Tuner
5.) Gears/T-lok Differential for a 7.5" rear end (also will need differential oil and a bearing kit for the install) + price of install
6.) Shift Kit (auto) short shifter/performance clutch (manual)
7.) 9mm Spark Plug Wires/New Spark Plugs (helps with this next mods new energy requirements, oh they look cool to)
8.) Port Matched and Polished Upper Intake to 65 or 70 mm (56mm for 94-98), 65 or 70 mm Throttle Body (56mm for 94-98), Port and Polished Lower Intake, Port and Polished Heads, Head Job (rebuild the heads to make more power), Cam Swap (this is one of the main power makers), 24lb-30lb fuel injectors (will support your new hp rating), Mass Air Meter/Mass Air Flow Sensor set to your fuel injector rating. This mod should be done all at once to save on install and shop charges. Should also consider forged internals.
9.) Ceramic Coated Headers
10.) Supercharger/Turbo Charger
Old Jul 19, 2006 | 03:19 AM
flash20's Avatar
flash20
dam jthorn how long did it take u to type that thing.
Old Jul 19, 2006 | 01:43 PM
jthorn9's Avatar
jthorn9
The Godfather
Only about 2 minutes.
Old Jul 19, 2006 | 01:45 PM
BeachStang04's Avatar
BeachStang04
lmao i think you covered it all there jeremy.
Old Jul 19, 2006 | 01:46 PM
jthorn9's Avatar
jthorn9
The Godfather
Well yep, I pretty much did as that's about all of the mods you can do to a sixer without just getting plain stupid with the mods. Oh, add in an aluminum driveshaft as the last mod.
Old Jul 19, 2006 | 01:50 PM
BeachStang04
lol then you get to adding things like roof scoop, turbonators, the big wing!!!
Old Jul 19, 2006 | 01:53 PM
jthorn9's Avatar
jthorn9
The Godfather
Oh, don't forget the nos in the little CO2 containers that are used in paint ball guns.
