Twin Turbo
garret has those new hybrids out, sooo easy to spool, look into those, actually i might suggest a 3:73 for a turo/Sc, not sure ask in pipes/juice. Turbo Mustangs TMA Turbos
ive got my stock t-lock and running close to 600 hp. unless you have hudge *** drag tires, and 700+hp theres no need to upgrade it untill you NEED it. even though i do highly suggest det. over any others. also aroung 125 is the average miles someone will come in and say that they THINK it may be acting up.
ORIGINAL: 04Mach1DD
www.tmaturbo.com turbo mustangs.com MAC cold air intake, pypes X pipe, flowmaster mufflers. 4:10 and a FORD T-Lock(no need for anything better then that even with TT) NO LOWERING KITS, SPRING KITS, or Handling kits. For the 3.8l i suggest Roush, of course. Get some rimes, body work and u got a sweet stang!
1st 4.10's are usless with a turbo. 3.45's are optimum with the 7.5 rear
2nd Ford T-lok IS NOT A PERFORMANCE PART it is stock replacement design left over from Bronco II's and Rangers that had T-lok optioned 7.5's. it WILL NOT SURVIVE BEHIND A TT SETUP the spyder gears are small and weak in the Ford T-lok not to mention the clutch packs do not live long behind alot of power. i replaced mine twice before i chucked the ford t-lok for a detroit truetrac.
Detroit Truetrac,TA rear girdle,TA bearing cap stud kit. this is NEEDED in a 7.5 to handle a TT or turbo setup or for that matter is a very wise choice for a procharger too.
why spend money putting in a cheap *** stock replacement weak differential and spend $4000+ on power mods. doesn't make sense. do it right the first time
a roush kit or kenny brown kit will reall make the car handle but also make the turbo car harder to launch. i still agree with you on the kit though as a drag setup is a poor street setup.
ORIGINAL: BeachStang04
if your going with a twin turbo setup deff. go with 4.10's man i wouldnt do it any other way!!!! Also you dont have to worry about it being street legal and what not. as long your x pipe is catted then you will pass emissions and everything is good, unless your state dosent do emissions testing then go with the o/r(off road) x pipe.
please don't give advise on gears for turbo's cause you know nothing about it obviously. nobody runs 4.10's with a turbo street car. 3.73's are really too much gear but usable
3.45's for the 7.5
3.55's for the 8.8
stock 3.27's are also OK for a turbo
ORIGINAL: 04Mach1DD
