02 weight distribution
Old May 21, 2004 | 10:49 PM
N_Jack's Avatar
N_Jack
Default 02 weight distribution
anyone know the front to back weight distribution on an 02 3.8 mustang? i've looked everywhere and i can't find the numbers for it
Old May 25, 2004 | 12:22 AM
VertStangGT86's Avatar
VertStangGT86
Default RE: 02 weight distribution
If I had to guess I'd go with around 60/40 considering that's what the braking distribution is. Why did you want to know?
Old May 25, 2004 | 12:33 AM
Ftr-Speedy's Avatar
Ftr-Speedy
my guess would be suspension fine tuning, thats what most weight distrubution info is for. sounds like he is a racer maybe.
Old May 26, 2004 | 09:30 PM
N_Jack's Avatar
N_Jack
'fraid not speedy, i'm just looking ahead to winter and wondering how much weight its going to take to make it handle a little bit better in the snow, or if i ought to just trade it in. ain't got the $$$$$ for racing yet and if i did i'd get something bigger than a 3.8 ya know?
Old May 27, 2004 | 03:35 PM
Ftr-Speedy's Avatar
Ftr-Speedy
all u need for winter is one sandbag. just one makes alot of diff. 2 is even better one over each tire well in the back. as for ya know bout something bigger, no i really don't, sometimes more horse aint always better if u can't get it to the track and hook it up good.
Old May 27, 2004 | 03:56 PM
HRnB's Avatar
HRnB
Administrator
I think mine is posted in the drivers side door jamb.
Old May 29, 2004 | 01:36 AM
VertStangGT86
Weight distribution isn't as important as traction in the snow, get a couple of the tube sands for the trunk. I've driven mine for a few winters cause I havn't had anything and it can be done if you know your car. Havn't really had any close calls or anything, just have to have a good set of winter tires. You're v6 has to be a lot better then mine.
Old May 29, 2004 | 01:50 AM
Ftr-Speedy's Avatar
Ftr-Speedy
try an 88 2.3L with bald tires, WWOOOO that was an intersting first winter drive ever. my first winter driving bald tired, rear wheel drive, no weight. YA alot of close calls. i reached a dead stop at a stop sign with a friend in our small town where they don't plow the roads, so the snow gets packed down, i dropped it into first gear, dumped the clutch, floored it, shifted to 2nd then to 3rd and 4th gear, finally hit 5th gear in seconds, looked around and my car didn't move one bit. pretty sad to reach 5th gear and not moved ne where. plus the run in with the median and the corn field doin 70mph, ok that one was my own stupidity gettin to me.
Old May 29, 2004 | 07:39 PM
N_Jack's Avatar
N_Jack
thanx, hotrods-n-booze i'll check that out
as far as the rest, i don't have a problem once i'm on the road, its starting from a dead stop that can be a bugger, even with 100lbs in the truck like i had last year. i'm going to get new tires for sure, but i just want to make sure i got the problem taken care of, i got an auto and i'd rather not have to redo the tranny if i don't have to.
Old May 30, 2004 | 02:19 AM
VertStangGT86
Yea, sometimes with snow I have to start in second even with snow tires. I just look at it as a challange[8D]
