Hello,
Old Jun 5, 2004 | 11:08 PM
Ranger427's Avatar
Ranger427
Default Hello,
I need somehelp. My turn signals don't work. Here are the symptoms: emergency flasher lights works, all bulbs are not broken/burned out, I replaced the flasher/signal relay (the silver cylinder on the fuse panel), I also replaced the multi-function switch (on the steering column). NOTHING HAS WORKED[:@]
What did I miss??? Help.....the police has already given me a warning to fix it or I'll get ticket.
Thanks
Old Jun 6, 2004 | 11:37 AM
Krusher's Avatar
Krusher
Default RE: Hello,
make/model/year?
Old Jun 6, 2004 | 06:25 PM
e40water's Avatar
e40water
Default RE: Hello,
I would bet money on it, you turn single switch is done, What happens over time carbon inside the switch connectors wearout it causes the switch to fail.
Old Jun 7, 2004 | 10:46 AM
50fiend's Avatar
50fiend
Default RE: Hello,
I got the same problem. Identical. Sorry no solution though.
Old Jun 7, 2004 | 12:06 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Hello,
Hmmmm, well if you can't succede in finding the problem - you could always install a toggle switch (HEY DON'T LAUGH - I DID IT ON A CAMERO ONCE!)
Best thing to do if you really wanna fix it is to get a repair manual and follow the wiring diagram and look for bad wires and parts. You'll need a volt / ohmmeter for this. Its a simple circuit - from your turn signal cam on your steering column to a fuse / relay / and flasher and then to your turn signal bulbs. When you bump your turn signal lever you should see the closed circuit for whichever side you chose being sent from it. Follow along in this manner until you find the problem.
Like I said before, you could always install a toggle switch until you find the problem
