Next mod, if any?
Old Aug 19, 2006 | 07:49 PM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: Next mod, if any?
Gears quicken accelleration time by increasing the amount of rotations the drivetrain makes per tire rotation. Now as far as gear sizes go, this is going to start a fight, if you do a lot of racing, then get 4.10s, if you're more conservative and are looking for a decent amount of accelleration, then get 3.73s. A t-lok eliminates the one wheel open differential that you have, in other words, only your right wheel is supplying power while the left acts as the traction wheel, a limited slip differential will allow for a little more hp to reach the rear wheels by allowing both wheels to supply the power. Install will run around $250-400 and you'll also need a rear bearing kit.
Old Aug 19, 2006 | 07:52 PM
v6stang07's Avatar
v6stang07
Another mod you could consider would be a new throttle body with a spacer. It should add a little horsepower. Gears are also a good choice though also.
aynjell's Avatar
aynjell
So the limited slip differential should in theory, increase horsepower? Hrm, that's a bit more my thing. I'll probably look into that after I get CAI, since that seems to be a great starting mod. Anyway, back to original poster, thanks for answering my question!
Old Aug 19, 2006 | 08:57 PM
mustangman02232's Avatar
mustangman02232
i would personally recomened 4.10s, and a detroit true trac unit for gears
Old Aug 19, 2006 | 09:07 PM
Autobadges.com's Avatar
Autobadges.com
Banned
Gears and Tlok fo' sho'
Old Aug 19, 2006 | 09:16 PM
mustangman02232
ORIGINAL: Autobadges.com
are you running an FFRP tlok or something else?
Old Aug 19, 2006 | 10:30 PM
jthorn9's Avatar
jthorn9
The Godfather
ORIGINAL: v6stang07
Ummm........... a TB spacer won't do jack diddely squat, and a throttle body will only add hp if your upper intake is port matched to the new size, and will only reach its full potential if the entire intake is ported with a cam swap.
Old Aug 19, 2006 | 10:35 PM
Autobadges.com
Banned
ORIGINAL: mustangman02232
yes
and right on jeremy
Old Aug 20, 2006 | 12:48 AM
mustangman02232
yes
and right on jeremy
7.5 or 8.8?
Old Aug 20, 2006 | 01:00 AM
jthorn9's Avatar
jthorn9
The Godfather
Unless you plan on breaking 300+ hp, the 7.5" will do you just fine.
