Autocross Setup??
Old Aug 28, 2006 | 12:54 AM
  #21
03YellowPony's Avatar
03YellowPony
Default RE: Autocross Setup??
ORIGINAL: Rook6
ORIGINAL: 03YellowPony
The only real bad(and it's not that bad) characteristic is when you go to turn REAL sharp, it will push in the tight turns. Understeer. But with good tires, and stiffening the car as I suggested, that understeer will be minimalized.
Ah so it does push? See I'd read alot that GTs had a nasty tendancy to plow through corners as a result of the heavy front weight bias though I'd thought 6ers wouldn't really have that problem with the lighter engine.
Now, help me here, do thicker/stiffer sway bars out back increase a car's tendancy to oversteer or understeer? Never been quite clear on that.
First off, 6ers don't come with rear sway bars. Second, the flatter you can keep it in a turn, and with better tires, the tendancy will be greatly reduced. But there will always be some understeer due to the fact the engine is sitting up front.
Edit~
Another tip I did with my 87 Buick when I autocrossed her. Use a dremmel tool and elongate the lower mounting holes on the struts. This will allow you to adjust for a negative camber. With 1 or 2 degrees of negative camber, and the other things I recommended, you will all but eliminate understeer. Yes, there will be a little, but not much.
Old Aug 28, 2006 | 01:16 AM
  #22
Rook6's Avatar
Rook6
Oh I can only imagine the out come of this hamfisted grunt taking a dremel to his Mustang, but it sounds like a good idea. Then again I could always use an excuse to get caster/camber plates.
Another question, it's a hard one to ask as I know a corner has multiple parts inducing multiple conditions, so try and bare with me.
A given car with no swaybars, when reaching limit of traction in a continual radius turn, slides neutrally, in that front and rear tires release together. If you were to add a REAR swaybar, would the car, all conditions identically reproduced, understeer or oversteer?
Old Aug 28, 2006 | 01:47 AM
  #23
03YellowPony
ORIGINAL: Rook6
To the best of my knowledge, with the conditions you set up, it will induce oversteer.
Old Aug 28, 2006 | 01:52 AM
  #24
Rook6's Avatar
Rook6
Why is that?
Old Aug 28, 2006 | 02:39 AM
  #25
03YellowPony
ORIGINAL: Rook6
Why is that?
By stifening the rear, and not the front, the front will plow and the rear will swing around. That's oversteer
Old Aug 28, 2006 | 03:24 PM
  #26
Xatrius's Avatar
Xatrius
What would be mor effective?
Turbo
Supercharger
Naturally Asperated
I'm personally a fan of the low end torque curve you can achieve with an N/A set up. But thought maybe the forced induction would give a nice boost in acceleration after each turn.
Thoughts?
ALSO, I posted in the Autocross sticky, was just wondering if people check it much, or if I should repost my question here.
Old Aug 30, 2006 | 01:36 AM
  #27
Xatrius's Avatar
Xatrius
Lethaldosage423
Oct 19, 2015 12:12 AM
fastbackford351
Oct 1, 2015 12:24 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
Drastang
Sep 29, 2015 03:31 PM
