Mods list, any suggestions?
I have a 1998 Autotrans and looked at some of the advice given to others on mods so i made a list of things, i just was wondering if i could get some suggestions/feedback.
CAI: BBK, Purchased
Exhaust:
-Flowmaster: ForceII with Y-Pipe
-Hooker: Cat-Back (Dunno if it comes with Mufflers or w/e)
-Pypes: Y-Pipe, by Pypes
Pulley: ASP 25% from Autobadges
Anything else vital to performance, but doesnt require an overhaul?
CAI: BBK, Purchased
Exhaust:
Here's my old mod list for my 98, hope this helps a little.
Air Intake
1.) K&N Air Filter (complete) $20
2.) Cold Air Intake (complete) $50
4.) 80mm Cobra MAF set to 24lb injectors
5.) 56mm BBK Throttle Body (complete) $255
Engine
1.) 25% Size Reduced Crank Pulley (complete) $50
2.) Reduction Billet Aluminum Water Pump Pulley (complete) $65
3.) Goodyear Replacement Pulley System Belt (complete) $30
4.) Diablo Predator ECU Modifier (complete) $275
5.) BBK Aluminum Valve Covers $350 @ v6mustangstuff.com
6.) Ported Upper and Lower Intake (semi complete) $0
7.) Port Matched Heads
8.) 24lb Fuel Injectors
9.) 210/218 Duration .53/.55 Lift Mild Tune Camshaft $275 @ supersixmotorsports.com
10.) Stud Mount Adjustable Roller Rocker Arm Kit $495 @ supersixmotorsports.com
11.) Cam Thrust Spacer Roller Bearing Kit $150 @ supersixmotorsports.com
12.) Spring Retainer Kit $225 @ supersixmotorsports.com
13.) Forged Engine Internals from supersixmotorsports.com approx. $1600
Ignition
1.) Red 9mm Spark Plug Wires (complete) $70
Exhaust
1.) JBA High Flow 2.5†Short Tube Headers $225 @ rdmotorsport.com
2.) 2.5†X-Pipe (complete) $200
3.) Magnaflow 2.5†Cat-Back Duel Exhaust (complete) $400
Drivetrain
1.) Ford Racing Posi-Traction 7.5†Differential (complete) $199
2.) 3.73 Motive Performance Plus Gears (complete) $149
3.) Motive Bearing Kit (complete) $79
4.) 23 Tooth Speedo Corrector - (complete) $29
5.) 2500 RPM Stall Torque Converter
6.) Shift Kit
Wheels
1.) Baer Claw Front Break Kit - 2 12†Front Breaks, Break Calipers, Break Lines, Break Pads $585 @ rpmoutlet.com
2.) Baer Claw Rear Breaks - $250 @ rpmoutlet.com
3.) 17’’ Saleen Replicas (complete)
Body
1.) Double Stack Saleen Wing
2.) Saleen Body Kit
3.) Saleen Hood
Accessories
1.) 5% Black Window Tint
2.) Cobra Clear Tinted Headlights
4.) Restore Paint
Suspension
1.) Bullet Suspension Kit - 1.5“-2†Eibach Sprigs, Anti Roll Bars, Tokico Performance Shocks $400 @ rpmoutlet.com
2.) Eibach Adjustable Caster Camber Plates & Bushings $105 @ rpmoutlet.com
Interior
1.) Black Carpet
2.) Red & Black Corbeau Racing Seats
3.) Black Door and Dash Panels With Red Airbag Cover, Speaker Covers, and Unit Control Covers
4.) 160 MPH White Face Speedometer
Sound
1.) Sony X-Plod Stereo (complete) $250
2.) 4 5†X 7†Boston Acoustic Speakers (complete) $300
3.) 1200 Watt Sony X-Plod Amp (complete) $300
4.) 2 275 Watt JL Audio Speakers (complete) $250
5.) Speaker Box (complete) $100
Air Intake
Engine
Ignition
Exhaust
Drivetrain
6.) Shift Kit
Wheels
Body
2.) Saleen Body Kit
3.) Saleen Hood
Accessories
4.) Restore Paint
Suspension
Interior
1.) Black Carpet
Sound
OH here are some sites for you to check out to get what's on that list.
autobadges.com
v6mustangstuff.com
brothersperformance.com
mustangtuning.com
jegsperformance.com
autobadges.com
v6mustangstuff.com
mustangtuning.com
jegsperformance.com
You may also wanna check these guys out for a little more flare under the hood.
www.hosetechniques.com
do not get a reverse Y pipe, get a set of GT take offs from a junk yard and get those put on, then get a set of force flow mufflers from summit racing for $30 which sound BETTER then flows and have a life time warrenty
ORIGINAL: mustangman02232
I believe that's highly debatable.
