any good?
i was just lookin around on some different sites and came accross this. does it look any good to you guys? anyone have one? i realize it wont do as well as what they say but is it worth it?
its the 2nd down on the left (Screamin' Demon Coil 94-00)
http://www.v6mustangstuff.com/engine.htm
Yea it probably will work as it's the same basis that handheld tuners use to increase hp, but remember, higher spark may mean having to use highe octance, or having to get your air to fuel mixture reset.
ORIGINAL: jthorn9
the more air between the ceramic insulator and plug body the hotter the plug. colder plugs have much less air gap, thus retain less heat. the heat retained by the plug when running too hot of a plug ignites the fuel before timed stark event. this is detonation and is bad because the pistion is still on the way up and the detonation wants to force the piston back down the opposite direction of the engine rotation. this is why you get bent rods,hammered rod bearings and cracked pistons from detonation
so if i get it sometime in the near future should i open up the plug gap a little bit or should i leave em? and cobra...so are u just sayn that i wont need to use higher octane fuel or what? i thnk if i do get it, i will just fill up w/ reg and if it starts knockin or whatever ill upgrade a level.
so 4-5 hp for 90 bucks...thats about $20 per pony. sounds good enough for me. udp's and that are the next things on my list. this is when i wish i wouldnt have done a few things like the chin spoiler and gas cap.
