UDP's ??
Old Sep 13, 2006 | 01:48 AM
  #31
zader_04's Avatar
zader_04
Default RE: UDP's ??
its a 95.. can you change shiftpoints and all that lil stuff like that with that tuner, and off the top of your head, you know how much they run $$$$$
Old Sep 13, 2006 | 01:50 AM
  #32
amrcnidyot's Avatar
amrcnidyot
$399..you wont find much better
Old Sep 13, 2006 | 01:51 AM
  #33
zader_04's Avatar
zader_04
yea i ddin't see that you wrote what i just re-wrote lol, so if i buy the CAI the UDP and a tuner, what kind of power gains am i looking at 15 or 50?
Old Sep 13, 2006 | 01:52 AM
  #34
bain_bk's Avatar
bain_bk
ORIGINAL: africkanV6
ok well the udps wont mess with ur windows or top. and since u dont use A/C that much u should be fine..if u get 42%udps ur lights might flicker slightly when ur idleing but i HIGHLY doubt it
42% pulleys will have n effect whats so every. I still run my A/C fine and nothing is lacking in power. The headlights can dim a little when nailing the gas to WOT but this happens alittle any way but you will not even be able to notice. The only way i would tell you not to get them is if you had a 2000 watt or higher system may need to upgrade the alternator.
Old Sep 13, 2006 | 01:58 AM
  #35
bain_bk's Avatar
bain_bk
ORIGINAL: zader_04
Dont hold me to this but i think the 95 requires a different tuner. jeremy will have to let you know on that.
Well i would say with your exhaust, intake, udp and tuner you would get about 15 more hp to the wheels 20 at max. But to really make this get to the ground easier is to get the gears and posi. On a 95 i would run 3.55 or 3.73 gears and some kind of posi unit. Ypu will notice a difference with just the bolt ons but the gears and posi really put all that on the ground. With out the posi unit you only have one wheel putting the power to the ground and with a posi unit it will have both wheels going. It will feel like a new car
Old Sep 13, 2006 | 02:04 AM
  #36
jthorn9's Avatar
jthorn9
The Godfather
Here's a good mod list for you. No you need a different tuner for the 94-95 models as they still used the old EEC IV ecu, both the diablo and sct are based around the EEC V.
Air Intake
1.) MAC Cold Air Intake $170 @ autobadges.com
4.) 80mm Cobra MAF set to 24lb injectors
5.) 56mm BBK Throttle Body $249 @ V6mustangstuff.com
Engine
1.) ASP 25% Size Reduced Crank Pulley $72 @ autobadges.com
2.) Billet Aluminum Water Pump Pulley $65 @ rpmoutlet.com
3.) ASP Underdrive Pulley Belt $35 @ autobadges.com
4.) Tweecer RT Tuner 86-95 $399-599 @ tweecer.com
5.) BBK Chrome Valve Covers $329 Silver $199 @ hillbankmotorsports.com
6A.) Stage 2 (AUTO) Powerpack $1725 @ supersixmotorsports.com
6B.) Stage 2+ (MANUAL) Power Pack $1950 @ supersixmotorsports.com
6C.) Stage 2+ (AUTO W/STALL) Power Pack $1950 @ supersixmotorsports.com
6D.) Stage 3 (FORCED INDUCTION) Power Pack $2375 @ supersixmotorsports.com
6E.) Basic Split Port Intake Swap Kit $720 @ rpm-mustangs.com
6F.) 99+ Stage 2 (AUTO) Powerpack $1800 @ supersixmotorsports.com
6H.) 99+ Stage 2+ (MANUAL) Power Pack $2200 @ supersixmotorsports.com
6I.) 99+ Stage 2+ (AUTO W/STALL) Power Pack $2200 @ supersixmotorsports.com
6J.) 99+ Stage 3 (FORCED INDUCTION) Power Pack $2350 @ ssms^^^
6K.) Split Port Swap Gasket Kit (no intake or heads) $310 @ rpm-mustangs.com
8.) 24lb Fuel Injectors $279, 30lb $275, 42lbs $359 @ jegsperformance.com
9.) Stud Mount Adjustable Roller Rocker Arm Kit $495 @ supersixmotorsports.com
10.) Cam Thrust Spacer Roller Bearing Kit $150 @ supersixmotorsports.com
11.) Spring Retainer Kit $225 @ supersixmotorsports.com
12A.) Forged Stock Internals $1200 @ supersixmotorsports.com
12B.) Forged H Beams W/ 351W Rods $1600 @ supersixmotorsports.com
13.) BBK Fuel Pressure Regulator $109.99 @ brothersperformance.com
Forced Induction
1.) Nitrous Oxide approx $500 @ jegsperformance.com and many others
2.) Vortech Supercharger approx $3500, see vortechsuperchargers.com for info.
Ignition
1A.) Red/Blue/Yellow 9mm Spark Plug Wires $70 @ autobadges.com
1B.) Chrome 8mm Spark Plug Wires $100 @ autobadges.com
2.) see msdignition.com for the rest of your ignition needs
Exhaust
1A.) JBA Silver or Titanium Short Tube Headers $640.97 @ hillbankmotorsports.com
1B.) JBA Short Tube Headers $460.72 @ hillbankmotorsports.com
1.C) JBA Chrome Short Tube Headers $349.99 @ brothersperformance.com
2A.) 2.5†V6 O/R X-Pipe see pypesperformance.com
2B.) MAC 2.5†V6 O/R H-Pipe $160.50 @ hillbankmotorsports.com
2C.) 2.5†V6 High Flow Catted X-Pipe see pypesperformance.com
2D.) 2.5†V6 High Flow Catted H-pipe see pypesperformance.com
3A.) Magnaflow 2.5†GT Cat-Back Dual Exhaust $469.99 @ brothersperformance.com
3B.) Borla 2.5†GT Cat-Back Dual Exhaust $699.99 @ brothersperformance.com
3C.) Bassini 2.5†GT Cat-Back Dual Exhaust see bassini.com
3D.) Flowmaster 2.5†GT Cat-Back Dual Exhaust see flowmaster.com
4.) MIL Eliminators (for O/R systems only) $61.95 @ hillbankmotorsports.com
Drivetrain
1A.) Ford Racing Posi-Traction 7.5†Differential $199 @ v6mustangstuff.com
1B.) See drivetrainspecialists.com for more durable options
2A.) 3.73 Motive Performance Plus Gears $ 149.99 @ mustangtuning.com
2B.) 4.10 (Moderately Moded Apps Only) Motive Performance Plus Gears $149.99 mt
2C.) 3.73 Ford Racing Gears $199.99 @ v6mustangstuff.com
2D.) 4.10 (Moderately Moded Apps Only) Ford Racing Gears $209.00 @ v6ms
3.) Motive Bearing Kit $74 @ mustangtuning.com
4.) 23 Tooth Speedo Corrector -
Transmission Auto
1.) High RPM Stall Torque Converter see mustangsunlimted.com
2.) Shift Kit see mustangsunlimted.com
Transmission Manual
1.) Steeda Tri-Ax Short Shifter $179 @ autobadges.com
2.) Shifter Gasket Set $9 @ autobadges.com
3A.) Spec Stage 2 Clutch $333.95 @ mustangsunlimited.com
3B.) Spec Stage 2+ Clutch $399 @ mustangsunlimited.com
3C.) Spec Stage 3 Clutch $499 @ mustangsunlimited.com
Suspension
1.) Steeda Caster Camber Plates $229.95 @ autobadges.com
2.) Steeda Lower Control Arms $295.95 @ autobadges.com
3.) Steeda upper Control Arms $295.95 @ autobadges.com
4.) Steeda Lower Subframe Connectors $89.95 @ autobadges.com
5.) Eibach Pro Spring Kit $224.95 @ autobadges.com
6.) Tokico D-Spec Shocks $629 @ autobadges.com
7.) Ford Racing (Cobra) Break Kit $819.88 @ mustangsunlimited.com
8.) 17†or 18†Rims see tirerack.com
Body
1.) Body Kits see mrbodykit.com, cervinis.com
Interior, Exterior, and Under Hood Visuals
1.) See mustangsunlimited.com, mustangtuning.com, and autobadges.com
Old Sep 13, 2006 | 02:10 AM
  #37
bain_bk's Avatar
bain_bk
I thought i remembered you saing that the 95 had a different tuner. Nice *** list, you have have that saved so you dont have to type it out every time dont ya.
Old Sep 13, 2006 | 02:12 AM
  #38
bain_bk's Avatar
bain_bk
might as well go ahead and make that a sticky so you dont have to repost it. But no one every looks at the stickys.
Old Sep 13, 2006 | 02:14 AM
  #39
amrcnidyot's Avatar
amrcnidyot
you just love that list dont you jthorn? i see it in every other post on here. lol. it is a great list of stuff though. just stuff that i cant afford sadly.
  #40
vponymike6's Avatar
vponymike6
from everyone i have talked to about them I heard they are a no for us sixers...Also they can lead to future engine/pump problems..
