Dual Exhaust Question
Hello. First time poster with 2000 V-6 exhaust questions. Is there any significant difference in performance the available V-6 dual options?
Catted Y-pipe to dual
vs.
"True dual options:"
Catted X-pipe
Catted H-pipe
Catted Straight pipe
Additionally, it seems that most do not like the y to dual option. However, is there much difference between an X pipe and two pipes that come together in and out of a y-shape? It seems like it would just be a more curved X.
Thanks.
vs.
Catted X-pipe
Catted H-pipe
Thanks.
w/ the y pipe in there it forces all of the exhaust into that small little 1 pipe length for a min. w/ an x or h the exhaust isnt forced into one small opening, it is simly just spread out through both pipes. id go x, h, or straight. i have straight w/ force mufflers and turndowns on mine. sounds really good for a 250 dollar exhaust
Definently remove the ypipe! Get a shop to do a custom job with straight catted pipes and whatever muffler u want welded in.. i got original 40 flows, but muffler choice is highly opinionated. My custom job was an even $300 for straight pipes flowmasters and chrome tips. Some people say that an X or H pipe isn't really needed for a v6 because we have even fireing engines...but i'm sure the experts on here have more to say about it
Not much of a difference in hp, but there's generally a huge difference in sound.
1.) O/R Y pipe units are generally much higher pitched than true dual
2.) Catted Y pipe units sound barely any different than stock
3.) Straight Pipes are generally fairly loud, but that's about it, just loud, not neccessarily good sounding
3.) Catted H pipes will have a decent tone with a very slight hp edge over the previous systems
4.) Catted X pipes are the same as the h pipes, just a little milder sounding
5.) O/R H pipes are generally fairly loud, but also retain some sound quality, but they do get a little weird sounding in the upper revs, offer the most hp possible, but yet again isn't that much of a difference over the others
6.) O/R X pipes are a little more milder sounding than the O/R h pipes, but retain much more of their upper end sound.
what about twin pipes that dont connect??? so each 3cylinders has its own dedicated pipe????? what difference does that do??? & how come no one discusses them???
ORIGINAL: jthorn9
Those are generally the same as an h pipe, some people put cats and mufflers on them, some mufflers, some nothing at all. Personally I find them to be very similar to h pipes of you do a catless set up, but I'm an x pipe man myself.
so on an x-pipe the pipes actually cross inside?? so the left 3 cylinders comes out the rear left exhaust & the right 3 cylinders comes out the rear right exhaust? & that just makes it sound different??
Catted = CO2 = Global Warming = Bad For Environment = Bad For Humans
No Cat = CO = Smog = Health Hazards = Bad For Humans
Whatever Happed to the 1997 Super Stallion concept car that was Flex Fuel (E85)?
THERE IS NO SUCH THING AS GLOBAL WARMING, OR THE GREEN HOUSE AFFETCT, ITS BEEN PROVED
ORIGINAL: Torroba
