What else do i need?
Old Oct 1, 2006 | 06:35 PM
Venkat's Avatar
Venkat
Default What else do i need?
So i'm gonna order 4.10s on enitrely stock v6 2004 mustang. What else will i have to change when i install the gears?
Old Oct 1, 2006 | 06:39 PM
africkanV6's Avatar
africkanV6
Default RE: What else do i need?
get a detroit trutrac to install at the same time. and a motive bearing kit
Old Oct 1, 2006 | 07:49 PM
03YellowPony's Avatar
03YellowPony
Bearing kit for sure, a LSD if you like, it makes sense since there won't be any additional labor charges, a hand held tuner or speed-cal to recalibrate the speedometer, and some good quality dif lube. I recommend Royal Purple.
Old Oct 1, 2006 | 08:15 PM
Omnislash27's Avatar
Omnislash27
What does the LSD do in the first place?
Old Oct 1, 2006 | 08:21 PM
mustangman02232's Avatar
mustangman02232
ORIGINAL: Omnislash27
puts power evenly to both wheels instead of just 1
Old Oct 1, 2006 | 08:46 PM
tims 88 4's Avatar
tims 88 4
thats what a detroit true track is isnt it
Old Oct 5, 2006 | 12:37 AM
BSmoothM5's Avatar
BSmoothM5
Do the TrueTrac and the gears at the same time ... it only makes sense. Does anyone know why you would need a bearing kit? I've heard if you've had 'high mileage', but whats the number? I have an 03 with 51k on it.
Saved up and getting gears and the truetrac this month...
Old Oct 5, 2006 | 01:34 AM
03YellowPony
ORIGINAL: BSmoothM5
Why take chances. Do the bearings while everything is apart. That way you won't have to do them in like 25000 miles.
