would I?
Old Oct 8, 2006 | 01:21 AM
GregoryA44's Avatar
GregoryA44
Default would I?
would i still need the true trac for this kit? http://www.americanmuscle.com/xcal2-...r-oil-kit.html Or is that all i need?
Old Oct 8, 2006 | 01:42 AM
Flake6899's Avatar
Flake6899
Default RE: would I?
Yup I think you would.
Old Oct 8, 2006 | 03:09 AM
cisurfer's Avatar
cisurfer
thats also for the 8.8 not 7.5 rear
Old Oct 8, 2006 | 03:18 AM
GregoryA44's Avatar
GregoryA44
so i would have to get the rear end change to 8.8 or does my 2001 have 8.8 stock?
Old Oct 8, 2006 | 03:23 AM
cobra232's Avatar
cobra232
ORIGINAL: GregoryA44
you have a 7.5 and an 8.8 swap is not needed.
get a detroit truetrac and motive 4.10's if you want 4.10's and an install kit. use lucas gear oil. friction modifier isn't needed with a detroit
get an SCT Xcal2 from www.vmptuning.com
Old Oct 8, 2006 | 03:28 AM
GregoryA44's Avatar
GregoryA44
sry for question, but where can you buy motive gears and the install kit at? ive been looking at v6mustangstuff.com and mustangtuning
Old Oct 8, 2006 | 01:02 PM
jthorn9's Avatar
jthorn9
The Godfather
mustangtuning.com sells the motive gears, although I'd get the ford racing gears from V6mustangstuff.com as they're built a little stronger.
Old Oct 8, 2006 | 02:29 PM
amrcnidyot's Avatar
amrcnidyot
ORIGINAL: jthorn9
americanmuscle.com sells the motive gears, although I'd get the ford racing gears from V6mustangstuff.com as they're built a little stronger.
fixed.
