next move
Old Oct 11, 2006 | 02:49 AM
excursor4690's Avatar
excursor4690
Default next move
I just got pypes catback x pipes with mac long headers. what do you think I should do next?
Old Oct 11, 2006 | 05:12 PM
miamiman23's Avatar
miamiman23
Default RE: next move
TUNER AND UNDERDRIVE PULLEYS. THE TUNER HELPS ALOT, AND THE PULLYS SO U DONT ROB POWER FORM THE ENGINE. NOT THE SEXIEST MODS, BUT RELITEVLY CHEAP AND EFFECTIVE. OF COURSE, IF U HAVE MONEY, GO FOR A TURBO!!!
Old Oct 11, 2006 | 05:14 PM
amrcnidyot's Avatar
amrcnidyot
yea i would go w/ a tuner. give you a little power and the abillity to change just about anything. its also the next step twards getting gears.
Old Oct 12, 2006 | 01:50 AM
excursor4690
are the pullies that I saw on RPMoutlet great or are there better ones that you know about?
Where can I find the best gears?
Any information on a cam?
Old Oct 12, 2006 | 01:53 AM
Raven_pbr's Avatar
Raven_pbr
Hows pypes sound?
Old Oct 12, 2006 | 02:58 AM
fallfast90's Avatar
fallfast90
I would say tuner. Just due to the fact that when you decide to get gears, you will be able to change the speedo with it than have to buy a speed cal
Old Oct 12, 2006 | 07:21 AM
Xemeth's Avatar
Xemeth
ORIGINAL: Raven_pbr
Hows pypes sound?
I've heard clips and it sounds a bit higher pitched than other systems. I'm a MAC fan, myself. Or Borla, but those are like rediculously expensive. There's no need for an exhaust system that will outlive your car and probably you.
Old Oct 12, 2006 | 10:21 AM
jthorn9's Avatar
jthorn9
The Godfather
I'd say get these things in this order
1.) Tuner - won't add much hp, but if you're driving an auto it will seriously help, even more so once the gears are done as you'll need the tuner to set the ecu to the right gear ratio
2.) Gears and some type of limited slip differential such as the Ford T-lok or the much better Detroit True Lock
3.) Cold Air Intake (have just what you need in my sig) will deffinitly complement your exhaust
4.) U/D Pulleys (also have just what you need in my sig) they will not help accelleration buy only by the smallest of margins, but will make your dynos look better as well as improve mpg.
Old Oct 12, 2006 | 01:40 PM
mustangman02232's Avatar
mustangman02232
4.10s and detroit true trac and a tune
Old Oct 12, 2006 | 05:08 PM
HornyHornyHippo's Avatar
HornyHornyHippo
Do the underdrive pullies do much for hp?
