check engine soon light
for some reason my check engine light has popped on, since yesterday morning...
only thing i can think of that could be the problem, is i do need an oil change... which i will take care of this weekend. but the light has never came on for that reason before. also, this past weekend, i hit a bump too hard and knocked one of my flowmaster pipes (i have it dualed out) loose, so i had to get it welded back together. any suggestions or ideas? thanks in advance
k, i will def take it to the service center... just wondering because i take pretty good care of my car and this is kinda bothering me to see that light on. hopefully it is something small tho
I have almost 75k and my light is on too, im pretty sure its just a timed thing, because i called the ford dealership and they said around our mileage its time to change trans fluid, oil and some other stuff that i cant remember.
My friends came on a while back and he couldnt explain it either. When he took it in the code said that someone had broken into his car and tried to turn it on without the key. Somehow the mustang knows the key and turns on a shut down mode, making it impossible to turn on, until you put the key in it. It will turn on the light if that happens. I dont know if this is all true, but it is what the guys at the dealership told him. So check your car for any evidence of a break in.
