Install UDP
Old Oct 26, 2006 | 08:22 PM
Deepenough's Avatar
Deepenough
Default Install UDP
I ordered the option A Motoblue pulley kit from rpmoutlet.com about 4 days ago. It should be coming in soon. I called a store up here and they said they would rent me a Harmonic balalancer puller for $139.99 and when i bring it back they will give me all of that back... so its kinda like loaning i guess. Well anyways i know this motoblue kit differs from the ASP pulley it has a waterpump pulley as well or somethiing like that that comes with it. Can anyone who has installed this before give me a little guide on taking off the old pulleys and belt and then putting on the new ones? It would be alot of help... thanks! Oh and also does this kit come with instructions?
Old Oct 26, 2006 | 09:25 PM
3.8blackout's Avatar
3.8blackout
Default RE: Install UDP
$139.99?!?!??
seems like a bit much.... make sure you trust the store lol
Old Oct 26, 2006 | 11:08 PM
Omnislash27's Avatar
Omnislash27
I got the exact same kit, and yes the kit does come with instructions and all, but they are the worst instructions ive ever seen. But beware, the 2 pulleys will ship separately, so you wont get them at the same time. I say get them installed by someone else, like i did, which came to $70 altogether.If you dont have the correct tools, then you cant do it, which i didnt have. Overall, id say call a different place cuz $140 is too much.
Old Oct 27, 2006 | 12:03 AM
Deepenough's Avatar
Deepenough
Haha yeah the place is called Canadian Tire... you guys dont have it down in the states but up here in canada its one of the biggest stores around. Theyre a very big franchise. So yeahh i do trust them. i just hope i can do it mysellf even with the harmonic balancer puller...
Old Oct 27, 2006 | 12:35 AM
Omnislash27
well, do you have the belt puller tool thing? i cant think of the name right now sorry. If you dont have the tool that will pull the belt when you take it off, you cant do it.
Old Oct 27, 2006 | 11:31 AM
Jefferson's Avatar
Jefferson
Moderator
I saw that kit at CT when I did mine. I thought they had a cheaper one too.
the $139 is complete, you could do ANY car.
Old Oct 27, 2006 | 06:19 PM
CharcoalStang's Avatar
CharcoalStang
to get the belt off all you need is a good wrench to pull the tensioner and then just slip the belt off, once you remove the belt, remove the stock water pump pulley(pulley above the crank pulley), then loosen the crank bolt(very hard), once thats out put your balancer puller in and begin to torque the balancer out, once the balancer is out, put your new balancer in, i would advise getting a new bolt with the same thread as the stock crank bolt, but longer to tighten your balancer enough so that your crank bolt will grab, once your stock crank bolt grabs, tighten and torque to spec, the rest is easy, just put everything back where it was...theres a good write up about this in the "how to" stickys, overall its a pretty straight forward installation, just that you need to be carful and follow the steps correctly...
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
