overdrive explained....?
Old Oct 28, 2006 | 11:56 AM
peedizzle's Avatar
peedizzle
Default overdrive explained....?
pardon me if i sound totally n00b, but i dont kno the "tru" use of the overdrive.... can someone explain a lil bit?
Old Oct 28, 2006 | 12:37 PM
Stang562's Avatar
Stang562
Default RE: overdrive explained....?
its an extra gear, no real performance gain (if any)
Old Oct 28, 2006 | 12:40 PM
00raging stang's Avatar
00raging stang
it saves gas
Old Oct 28, 2006 | 12:42 PM
Stang562's Avatar
Stang562
yes it does, I thought i put it on my last post.... [&:]
Old Oct 28, 2006 | 12:56 PM
peedizzle's Avatar
peedizzle
i just notice that when the od is off, my flowmasters are like30% louder.... and the engine rins about 1000rpms higher
Old Oct 28, 2006 | 01:15 PM
jthorn9's Avatar
jthorn9
The Godfather
Overdrive changes the gear settings, as it causes you to shift to the next gear earlier than normal to save gas. OD off means there is no change in gears and you use all 4 gears like you would a manual, well almost anyways.
Old Oct 28, 2006 | 01:19 PM
peedizzle's Avatar
peedizzle
does it hurt my tranny or engine to switch in between on the fly?
example, like when on the freeway i'll sometimes do it to dig deeper in 3rd or second gear...
Old Oct 28, 2006 | 01:30 PM
jthorn9's Avatar
jthorn9
The Godfather
No, not if you do it every now and then, but do it every 10 seconds and you can expect something to go out.
Old Oct 28, 2006 | 01:36 PM
mustangman02232's Avatar
mustangman02232
it starts on always, turn it off it just locks it out of overdrive and nothing else, with it off you stay in your 1:1 gear, wile with it on it goes into forth, or overdrive, wich is .70 to save gas
Old Oct 28, 2006 | 01:38 PM
jthorn9's Avatar
jthorn9
The Godfather
Remember, KISS, remember, not everybody knows what gear ratios are and what .70 overdrive means.
