Removing Badges
Old Nov 5, 2006 | 11:10 PM
HornyHornyHippo's Avatar
HornyHornyHippo
Default Removing Badges
I would just like to know how im supposed to remove the bades on the front sides of the car. You know where it has the mustang in a circle with red white and blue for v6, gt for gt, and a snake for cobras. They are metal, and i dunno if they are glued on or bolted on or how they are attacked, but i just dont like them there and would rather it just be... black.
Old Nov 5, 2006 | 11:11 PM
da1nonlysteven's Avatar
da1nonlysteven
Default RE: Removing Badges
Some Goo-Gone, and dental floss
Old Nov 5, 2006 | 11:16 PM
jthorn9's Avatar
jthorn9
The Godfather
It's held on with both a sticky tar like caulk. Click on my sig, they have a step by step set of instructions that will help guide you in taking off your badges.
Old Nov 5, 2006 | 11:20 PM
HornyHornyHippo
Perfect, thats exactly what i was looking for. To bad there is a huge hole behind it, because then id have to get a badge just to cover it up. Oh well, thanks anyway!
Old Nov 5, 2006 | 11:32 PM
amrcnidyot's Avatar
amrcnidyot
i was gonna say your gonna have a hole there. im glad you found that before you ripped em off.
Old Nov 5, 2006 | 11:52 PM
Xeremeh's Avatar
Xeremeh
If you want, you can still remove them. Just go to your local hardware store and by some plastic caps. I can't remember what size it is, but I'm sure you can look it up on google. (There are a few guides used for removing spoilers and replacing the holes with these caps). Just buy them, then a small bottle of auto touchup-paint (the exact color your need should be found in your drivers-side door panel, or if not, I'm sure the store has a booklet you can look up ___ Mustang in.) Paint the suckers black, them put the plugs in the hole. If you do a clean job of it, they look just like a couple of small bumps on close inspection, and most people won't even notice them from a short distance. Just an alternative. =)
Old Nov 6, 2006 | 01:10 AM
HornyHornyHippo
Well the car was bought used so i doubt it has it in the door still. But just to make sure i understand you correctly, it should be in the side door pocket?
Old Nov 6, 2006 | 02:13 AM
amrcnidyot's Avatar
amrcnidyot
ORIGINAL: HornyHornyHippo
is should be on the edge of the door that has the actual lock that holds the door to the body when you close it. the part that faces the back of the car when the door is closed. or maybe its on the body in that same area...i dont remember now..
edit: it doesnt really matter anyway. the color code for your car is UA. they only make one black in 03 so that has to be it.
Old Nov 6, 2006 | 08:48 AM
HornyHornyHippo
alright cool, thanks
Old Nov 6, 2006 | 01:48 PM
penceman's Avatar
penceman
When my bro did it on his car, he just used fishing line.
