42lb injectors V6
Old Nov 8, 2006 | 02:55 AM
  #21
jthorn9's Avatar
jthorn9
The Godfather
Default RE: 42lb injectors V6
Probably not, but you really need to know exactly what rwhp you're pushing.
Old Nov 8, 2006 | 03:08 AM
  #22
dhuskers_11's Avatar
dhuskers_11
andy from tma said at 4.4 i would be pushing 250rwhp with a good conservative tune
Old Nov 8, 2006 | 01:46 PM
  #23
mustangman02232's Avatar
mustangman02232
ok so question you said your running 4.4 psi for TTs? does that mean your actually doing 9 psi through the motor?
Old Nov 8, 2006 | 05:11 PM
  #24
dhuskers_11
no it will be setup up to do 4.4 to the motor to start with
Old Nov 8, 2006 | 07:13 PM
  #25
deezelnut's Avatar
deezelnut
I ♥ Acer
don't split-port come with 21lb injectors stock?
Old Nov 8, 2006 | 08:23 PM
  #26
ddeaton66's Avatar
ddeaton66
Can you use the same injectors for the 3.8L as for the 5.0L?
Old Nov 8, 2006 | 09:26 PM
  #27
mustangman02232
ORIGINAL: deezelnut
you should know you have a supercharger
they come with 14s stock i believe
Old Nov 8, 2006 | 09:34 PM
  #28
dapack69's Avatar
dapack69
ORIGINAL: ddeaton66
Depends what year your talking about. The 3.8l up to 98 can use any 5.0 injector, after that then the answer is no.
Those debating of buying 42's for a turbo setup, skip them and go straight to 60's. The reason why I say that is eventually you will turn up the boost and run out of injector. Spend the money once instead of upgrading later and wasting the money.
Old Nov 8, 2006 | 09:38 PM
  #29
ddeaton66's Avatar
ddeaton66
thanks for the info!
Old Nov 8, 2006 | 09:41 PM
  #30
dapack69's Avatar
dapack69
Not a problem, I've owned a mustang for the past 14 years and had my current V6 for the past 6.5 years.
