acceleration problems
Old Aug 12, 2004 | 08:19 PM
DriftAngle45's Avatar
DriftAngle45
Default acceleration problems
I have a 2.3L with dual ignition and fuel injected. my car runs at a lower rpm than normal.... I cant go past full throttle until the rpm's reach above 3 grand. after than I can floor it. if I try to floor it at idle or before 3 grand it either boggs and the rpm's just start to slow down or the car bumps back and forth.. I can't figure it out. the check Engine light is not on so I cant run a computer diagnostics on it so I don't know what to do. if you have any info that would be great.
Old Aug 12, 2004 | 09:02 PM
Duffs302's Avatar
Duffs302
Default RE: acceleration problems
It could be incorrect timing, faulty or incorrectly gapped spark plugs, plug wire, air filter dirty, fuel filter clogged, vacuum leak etc....
Old Aug 12, 2004 | 09:07 PM
DriftAngle45
it has new spark plugs... Platinum so there isn't a gap setting. New spark plug wires. New fuel Filter. clean air filter... so I guess I could just start with the timing belt. thanx for the info.
Old Aug 12, 2004 | 09:16 PM
Duffs302's Avatar
Duffs302
I for got about the fuel injecter could be clogged, but it's always fun to try to fined the problem [sm=trust_me.gif]
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
zanemoseley
Sep 6, 2015 12:58 PM
