need injector help
Old Nov 11, 2006 | 12:58 AM
OpsShark213's Avatar
OpsShark213
Default need injector help
i just bought a 98 that the mech said has 2 bad injectors, will the inj. out of a 98 4.6 fit the 3.8 and if not has anyone got any stock injectors that they will part with. also need a pass. side door and front fender if anyone has one of those too. thanks
Old Nov 11, 2006 | 02:57 AM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: need injector help
Yes they'll fit, but you'll have to have your MAF recalibrated for 19lb injectors, your stock injectors are 14lbs.
Old Nov 11, 2006 | 03:56 AM
OpsShark213
how do u recalibrate it? and if i'm going to use the 19lb. gt injectors do i need to change all 6, or just the 2 that are bad?
Old Nov 11, 2006 | 03:58 AM
jthorn9's Avatar
jthorn9
The Godfather
You either buy a MAF from Ford that has been calibrated (factory settings) to 19lb injectors, or you buy one aftermarket. I suggest http://www.mustangsunlimited.com/ for aftermarktet.
Old Nov 11, 2006 | 04:09 AM
OpsShark213
judging from the price i think i'll just buy 2 new 3.8 injectors, all the forums say that since the car is not heavily modded that i wouldn't see any proformace gain anyway . correct?
Old Nov 11, 2006 | 07:16 AM
deezelnut's Avatar
deezelnut
I ♥ Acer
ORIGINAL: OpsShark213
stock you won't get any more power with larger injectors, but if you go larger, like 24lb injectors, then you won't have to do it later.
Old Nov 11, 2006 | 12:59 PM
jthorn9's Avatar
jthorn9
The Godfather
Fuel injectors don't make hp, they support it. For example, my GT is making between 270-280 rwhp, ranges we got on dyno. Now my stock injectors are overloading at around that point, so no matter what I do, I'm not gonna really make too much more. Now if/when, I upgrade to 24lb injectors, I'll be capable of hitting higher hp numbers. For example, I can tune my car using my software program, anp probably push my rwhp numbers up to around 290 consistantly. Then when I get my intake, that "SHOULD" push me up to around 300 rwhp. Then add on the 100lb shot of N2O I have planned at that will put me at around 380 rwhp, which is roughly where 24lbers top out at on V8s.
Old Nov 11, 2006 | 02:28 PM
OpsShark213
yeah thats what i have learned is that until i boost my hp level up alot higher i don;t need to change the stock injectors. now has anybody got some stock 3.8 injectors that they can part with
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
MacSerio
Sep 27, 2015 01:05 PM
mltdwn12
Sep 23, 2015 08:54 AM
