what do i need
Old Nov 21, 2006 | 12:05 AM
hpwrestler220's Avatar
hpwrestler220
Default what do i need
if i get the 3.73 gear do i need anything else or can i just put that in my car and be set?
Old Nov 21, 2006 | 12:06 AM
Flake6899's Avatar
Flake6899
Default RE: what do i need
a tuner and a lsd
Old Nov 21, 2006 | 12:07 AM
tims 88 4's Avatar
tims 88 4
shims and spacers
Old Nov 21, 2006 | 12:09 AM
Crsytal Ice's Avatar
Crsytal Ice
u need a tuner, u DON'T need an LSD, but it is HIGHLY recomended, unless u like the one wheel peel
Old Nov 21, 2006 | 12:10 AM
HornyHornyHippo's Avatar
HornyHornyHippo
Whats an lsd again
Flake6899's Avatar
Flake6899
limited slip differential like a t-lok or true-trac.
Old Nov 21, 2006 | 12:19 AM
HornyHornyHippo
ahh, ok thanks
Old Nov 21, 2006 | 12:52 AM
HamMach1's Avatar
HamMach1
T-lok and tuner FTW!
Old Nov 21, 2006 | 01:04 AM
snakeman4life's Avatar
snakeman4life
You can buy a installation kit that includes shims,bearings,gaskets and everything else you need for about $100.You will also need gear lube.If you want to save money you can get a speedometer programer that just sets your speedo,which is alot cheeper than a handheld tuner.
Old Nov 21, 2006 | 01:21 AM
johnt2k7's Avatar
johnt2k7
50 resto sells a master install kit that has everything you need to do the swap includeing gear oil , gasket , and everything else
