3.73 = $$$
Either or would do just fine, the T-lok would probably be cheaper. At any rate, do some searching around, you might find that getting an axle from a GT that already has T-lok might be cheaper. I picked up an 8.8 for $200, it was freshly rebuilt too. Anyway, gears should run right around $200, install I wouldnt pay anymore than $250-$300.
-P.
-P.
ORIGINAL: P Zero
-P.
-P.
http://www.brothersperformance.com/ sells rebuilt 8.8" rear ends with the gears already in, and if you have a way to get your car fully off the ground, and a haynes manual, this is something you could "PROBABLY" do yourself, but if you feel, in any way that you can't, get a shop to do the install.
Gears - $170-200
T-Lok (will just fine for you) - $200
True Trac (a little overkill, but overkill isn't always a bad thing) - $450
Bearing Kit - $70
Tuner - $300-400 new
Install - $250-450
Gears - $170-200
Bearing Kit - $70
Install - $250-450
gears and bering kit you can get from http://americanmuscle.com/ the discount code is "mustangboards"
ORIGINAL: amrcnidyot
where the hell did you find that? i was lookin around and everything was about 800 bucks.
ORIGINAL: P Zero
-P.
-P.
-P.
