quick question
Old Dec 3, 2006 | 08:49 PM
Reikat's Avatar
Reikat
Default quick question
I'm thinking of upgrading the gears in my Automatic to give it more exceleration. Is it smart to put them in an automatic? and do I have to change the computer settings on the car to adapt to them.
And If it's ok then which set should I get... I was think just going all the wat and getting 4.10. How much will that decrease my top speed?
And if I have to change the Comp setting will a mechanic or a ford dealer ship be able to do. ( I don't have the money to buy a tuner or the knowlage of how to tyune it right.)
Thank in advanced...
Old Dec 3, 2006 | 11:44 PM
mustangman02232's Avatar
mustangman02232
Default RE: quick question
it wont decrease your top speed, you dont have the power to achieve it, you will still be drag limited to around 135
you also need an LSD unit
my vote, 4.10s and a true trac
Old Dec 4, 2006 | 12:15 AM
Reikat's Avatar
Reikat
hmm... I guess a better Diff. would be needed to handle the energy transfer...
Any idea how much they would cost each, or total... and what about the install... I can do some engine work but this is a little out my league...[sm=insomnia.gif]
Old Dec 4, 2006 | 12:22 AM
jthorn9's Avatar
jthorn9
The Godfather
Gears - $150-200
Limited Slip Differential - $200-450
Install - $200-450
Old Dec 4, 2006 | 12:29 AM
Reikat's Avatar
Reikat
So around $1200 ballpark... sweet... so only like 3 or 4 months of saving every penny I earn... alot cheaper than have in a manual tranny put in... but I might do that eventually too....
oh and if I have those installed what about the computer... will it need to be reset?
Old Dec 4, 2006 | 12:31 AM
jthorn9's Avatar
jthorn9
The Godfather
Nope, you're an early sn95, so all you'll need is the 23 tooth speedo gear, it corrects the speedo.
Old Dec 4, 2006 | 12:34 AM
Reikat's Avatar
Reikat
I guess the speedometer gears are pretty cheap? .... and easy to put in...?
Old Dec 4, 2006 | 01:08 AM
jj84756's Avatar
jj84756
i got quoted at $650 for everything. that included t-lock, 4.10's, all install parts and fluids, and labor. it's a good mod if you have the money. i was just going to stick with the t-lock because i don't plan on going all out high horsepower, so the t-lock would be sufficient.
Old Dec 4, 2006 | 01:25 AM
Reikat's Avatar
Reikat
t-lock? If you don't mind me asking what is that? I'm not familiar with all the abreviations...
Old Dec 4, 2006 | 01:27 AM
GregoryA44's Avatar
GregoryA44
ORIGINAL: Reikat
Ford racing t-lok http://www.v6mustangstuff.com/drivetrain2.htm
