LITER?
Old Dec 3, 2006 | 10:45 PM
98Ga's Avatar
98Ga
Default LITER?
is it possible to turn a 3.8L into a 4.0L?
Old Dec 3, 2006 | 11:00 PM
98Ga's Avatar
98Ga
Default RE: LITER?
could somebody please answer me
Old Dec 3, 2006 | 11:04 PM
Jugador's Avatar
Jugador
Default RE: LITER?
could you? i would assume you can make a 4.0 by changing bore and stroke somehow. is it common? ive never heard of an essex blocked 4.0. the common displacemental change to make with a 3.8 is to go to a 4.2 or 4.3 via a stroker kit. are you talking about swapping in a cologne 4.0 that they use in the new stangs and explorers and rangers? if so i bet thats an even worse investment than getting a 4.2 or 4.3.
Old Dec 3, 2006 | 11:06 PM
miamiman23's Avatar
miamiman23
Default RE: LITER?
supersixmotorsports.com has 4.2 and 4.3 stroker assemblies. But if you dont know much about engines (which im assuming u dont) you will have to get it proffesionally installed, which will get expensive.
Old Dec 3, 2006 | 11:07 PM
98Ga's Avatar
98Ga
Default RE: LITER?
keeping the same engine and turning it into a 4. anything.
Old Dec 3, 2006 | 11:09 PM
Jugador's Avatar
Jugador
Default RE: LITER?
i would go with the 4.2. if you're crafty you can get the parts from a 4.2 f150, though im not sure how involved that is. if you aren't too crafty then you can buy a 4.2 from ssm like previously suggested and pay someone to install it. if you take the second option you're probably going to have wasted your money
Old Dec 3, 2006 | 11:13 PM
98Ga's Avatar
98Ga
Default RE: LITER?
how much could it cost
Old Dec 3, 2006 | 11:19 PM
Reikat's Avatar
Reikat
Default RE: LITER?
any serious engine work like that, if you want it done well, will probably run you over $1000... probably more but that's aa very low guess-timate.
Old Dec 3, 2006 | 11:40 PM
mustangman02232's Avatar
mustangman02232
Default RE: LITER?
http://www.moranav6racing.com/catego...?CategoryID=16
slightly stroked 4.0 all the way up to a stroked 4.4
Halina
Mar 24, 2005 05:23 AM
stockcar3
Apr 3, 2004 09:56 PM
Quik
Feb 1, 2004 07:46 PM
stangnoob
Jan 22, 2004 12:21 PM
WhiteHawk
Jun 25, 2003 02:49 PM
