Engine Swap?
Old Sep 3, 2004 | 03:58 AM
tokijin's Avatar
tokijin
Default Engine Swap?
okay first of all i dont really know where to post so this seems like the best place.
anyway i have a 2001 mustang convertible and i am hopefully going to swap the engine with that of a 2001 cobra (the non-supercharged ones). first of all i was wondering if this is even possible as i cant find sufficent info on the subject. and second of all i was wondering where i could find a reasonably priced engine with close to 0 miles as possible short of buying a new cobra.
thank you for you feedback.
Old Sep 11, 2004 | 03:34 AM
Jimmz's Avatar
Jimmz
Default RE: Engine Swap?
Yes it is possiblea friend of mine bought one for his 99' V6, he went to MVP Performance in GA and got the engine installed with the tranny, 6 speed coversion and everything for about $11,000. I'm not sure where you live but you can also find alot of engines on Ebay. I've seen some 2003 mach 1 engines with 50 miles or less on them for about 5 grand.
Old Sep 11, 2004 | 03:58 AM
Jugador's Avatar
Jugador
for 5k you could probably get an 03 motor...
Old Sep 13, 2004 | 11:58 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
if you can find a new terminator longblock for under 8 grand buy it, they retail for around $12000 with tax.
Old Sep 14, 2004 | 02:43 PM
Brent's Avatar
Brent
Sell your car and actually buy the 01 Cobra. Your car resale value is going to go down the drain if you do something like that. You will be spending the same if not more doing a swap as if you just traded in your car.
He wasnt asking about a 03 Cobra engine he was asking about a 01 Cobra engine.
It can be done but you will need:
Upgraded Suspension
8.8 Rear End
Cobras Computer
The Actual Engine
The transmission (T-45 I believe)
Thats just off the top of my head things you will need. I am sure there are alot more I will think about and add
Old Sep 14, 2004 | 07:41 PM
Drizzt6534's Avatar
Drizzt6534
dont get an 01 cobra engine, the 03 is better. hints the most power out of any of the cobra engines. Get the 03 because it has an iron block with aluminum heads and so on. but it is also supercharged. then later if you want you can get new internals and push more boost.
Old Sep 14, 2004 | 11:20 PM
matthockey32
I ♥ Acer
the 03 cobra engine is rumored to be able to make 1000 rwhp on the stock internals. just buy a used 03 cobra.
Old Sep 14, 2004 | 11:29 PM
TattooTears's Avatar
TattooTears
ORIGINAL: matthockey32
Are the stock internals on the 03/04 Cobra engines forged?
Old Sep 14, 2004 | 11:58 PM
matthockey32
I ♥ Acer
yes. but that is also a rumor. i have seen one dyno at 750 on stock guts with a procharger kit.
Old Sep 15, 2004 | 10:02 AM
97Stallion's Avatar
97Stallion
Your engine is only as strong as it's weakest link. If you balance and tune the engine correctly, then it'll last long for many years to come.
Nick Oliver
Oct 17, 2018 04:22 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
97SN95GT
Sep 13, 2015 09:45 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
