Stroker question
Old Dec 14, 2006 | 12:34 AM
Xemeth's Avatar
Xemeth
Default Stroker question
I was looking at SSM's site, and I had a few questions.
I know getting your engine stroked means you increase the size of the stroke (piston movement, correct), thus increasing the power. How exactly would I go about stroking my 3.9L to a 4.2L? Would I need a new block or something? Or just a 4.2L crankshaft so the pistons move farther up and down?
Also, if I were to stroke to a 4.2, would 3.8L and 3.9L parts still fit? Say UDP's, or even a powerpak or a turbo made for a 3.8L? Or would I have to get special parts for the 4.2?
Basically I'm just looking for a good explanation of what exactly stroking is and how worth it it is on a 3.9L split port.
Old Dec 14, 2006 | 02:17 AM
v6kid07's Avatar
v6kid07
Default RE: Stroker question
i would assume the 4.2 stroker would fit right into our block because it doesnt say anything about needing a new block for these parts to fit
Old Dec 14, 2006 | 02:51 AM
Xemeth's Avatar
Xemeth
Well can anyone with pretty good knowledge just explain exactly what a stroker kit is/does?
Old Dec 14, 2006 | 02:54 AM
amrcnidyot's Avatar
amrcnidyot
you pretty much got it man. it increses the stroke of the piston creating a bigger combustion chamber. you dont need a new block. you use the stock block. almost all parts should still fit it, the stroker is all internal stuff. if you have a lot of detailed questions i would just talk to ssm.
Old Dec 14, 2006 | 03:04 AM
Clif Brohn's Avatar
Clif Brohn
All of SSMs stuff for the Essex will work with each other. The only thing you would want to worry about is if you got new heads, making sure you have the right type of piston for the application. Other than that, all a stroker kit is would be new rods/crank/pushrods, etc. Go for it, get it on a dyno
Old Dec 14, 2006 | 03:13 AM
SySt's Avatar
SySt
The stoker "kit" would include shorter rods, larger crank and pistons with more of a dish. That is unless you know what you are doing and would like to calculate all 3 compression ratios and rod length, etc.
Old Dec 14, 2006 | 01:08 PM
jthorn9's Avatar
jthorn9
The Godfather
You don't need a new block, instead your current block has to be pulled, stripped down, bored out, cleaned, maybe a fixer upper hear or there, and then reassembled with the stroker kit. Then intakes will fit just fine, as none of the bolting paterns change, but as stated earlier, the heads are the only thing you really need to worry about.
Old Dec 14, 2006 | 01:46 PM
Xemeth's Avatar
Xemeth
So say I ended up stroking to a 4.2, but still wanted a powerpak. I would just get the 97+ F-150 4.2 powerpak, so the heads fit, right? And everything else from UDP's to a turbo will still work?
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
