M-90 Supercharger
Because it's old and was made for GM, and Ford Supercoupe Thunderbirds. New they're still pretty pricey, like around $1500+, but used they're a great bargain. They add just as much hp as andy 7-9 psi supercharger does. They will only "EASILY" fit 94-98 V6 mustangs, so if you have a 99-04 you'll need to do a few more mods and adaptations to make it fit.
well i'll most likely have 3.73's, an sct xcal 2 tuner , a CAI and thats it i think. so those will be the supporting mods but what engine applications will i have to apply to get this supercharger bolted and working on my car?
https://mustangforums.com/m_2117045/...tm.htm#2117045
if you get a 94-95 blower with a 87-93 pully on it it will also increase the boost by 1 or 2 psi
on an average single port, you will get around 200 rwhp and 300rwft/lbs, if you do the swap, it would probably be easier to just swap the whole motor over
since you have an 01, you need to either get the hole motor, or convert yours back to single port,
or you could look at justin at vmptuning.com for an 11 psi procharger and you could end up around 300 rwhp, or talk to andy at TMAturbo.com and get a 14 psi turbo kit and be good for around 400 rwhp
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
