Springs
Old Dec 17, 2006 | 02:55 PM
TheMichiganRA's Avatar
TheMichiganRA
Default Springs
Alright, I have been looking at Eibach springs since I've gotten my car. I have a '03 coupe. I've been looking at their pro-line springs, not sport-line. I was thinking if I put these pro-line springs, which claim to drop it 2" in the front and 1.8" in the rear, on my car and I buy 18" x 9" front and 19" x 10" rear, with a 275-285 tire (I don't know much about the tire sizes), would that work? I'm pretty sure the rear will not be a problem, since it doesn't turn.
I don't know, what do you guy think? Let me know what kinda set-up you guys have on your Mustangs so I can get some ideas. What's the MAX you can drop your car with atleast an 18" rim?
Thanks.
-K
Old Dec 17, 2006 | 03:56 PM
jj84756's Avatar
jj84756
Default RE: Springs
yeah it shouldn't be a problem at all, but i would just stick with the 18's all around personally.
Old Dec 17, 2006 | 03:58 PM
amrcnidyot's Avatar
amrcnidyot
Default RE: Springs
if you drop it that low you will have to get some caster camber plates to adjust the front susspension
Old Dec 17, 2006 | 05:01 PM
v6stang07's Avatar
v6stang07
Default RE: Springs
i u go with the pro-kit get a camber bolt kit to realign instead of cc plates. much cheaper. i would also stick with 18's all around your tire sizes sound good tho. if u go with the sportlines, go ahead and get the cc plates.
Old Dec 17, 2006 | 05:02 PM
jj84756's Avatar
jj84756
Default RE: Springs
ORIGINAL: v6stang07
those camber bolts have been proven several times not to work. they will always need adjusting. don't be cheap. do it right the first time and get castor/camber plates.
Old Dec 17, 2006 | 05:14 PM
flash20's Avatar
flash20
Default RE: Springs
ORIGINAL: v6stang07
where did u got those at i want some
Old Dec 17, 2006 | 05:44 PM
jj84756's Avatar
jj84756
Default RE: Springs
ORIGINAL: flash20
ORIGINAL: v6stang07
i know you can get them from here but like i said i wouldn't mess with them. they don't work.
Old Dec 17, 2006 | 06:07 PM
GregoryA44's Avatar
GregoryA44
Default RE: Springs
i don't have plates, and i used the eibach pro-kit!
Old Dec 17, 2006 | 06:31 PM
TheMichiganRA
Default RE: Springs
Thanks guy. Gregorya44, how did/does your car feel now compared to stock? What do you think I should get?
-K
Old Dec 17, 2006 | 06:35 PM
GregoryA44's Avatar
GregoryA44
Default RE: Springs
omg, it handles so much better and rides better. I def would go with the eibach pro-kit, you cannot go wrong with it!
