why my car will not launch
Old Dec 20, 2006 | 08:31 PM
silverstang18's Avatar
silverstang18
I ♥ Acer
Default why my car will not launch
ok fellas here is a quick question, i have a 2000 3.8 auto. Whenever i am casually driving 40-45 mph etc. i sometimes feel the need to stomp the gas only to find out that my car does not launch. now sometimes it will, and sometimes it wont. why is that?? any advice is appreciated. do the rpms have to be somewhere before i step on it?
Old Dec 20, 2006 | 08:35 PM
232_01mustang's Avatar
232_01mustang
Default RE: why my car will not launch
maybe TCS...and maybe the rpm's arent high enough to make any difference in torque so it doesnt jump...
Old Dec 20, 2006 | 08:48 PM
SilvrStang's Avatar
SilvrStang
at 45 downshift it to D-2 u can then take off pretty damn fast. It can push it up to 70 mph and about 4500 rpm
Old Dec 20, 2006 | 08:52 PM
silverstang18
I ♥ Acer
yeah bro i use to do that all the time but my friend blew his transmission out of his chevrolet Z71 by doing that. atleast thats what he said, so is that not bad for your transmission??
Old Dec 20, 2006 | 08:55 PM
SilvrStang's Avatar
SilvrStang
mine isnt having any problems although i dont do it all the time maybe once in a while
Old Dec 20, 2006 | 09:49 PM
BillyBobJoe's Avatar
BillyBobJoe
biggest problem is that you have an auto. dont worry, you'r not the only one with an auto. . IF you floor it completely and it only shifts down to 3, if at all, then it could be that the TPS didnt register the full throttle and you may need to adjust the pedal to have more clearance to the floor and raise the pedal. Otherwise, I use the D-2 method sometimes and at 40-45 its usually ok cuz thats about where first gear ends. Just dont do it TOO often.
Old Dec 20, 2006 | 09:55 PM
Durr727's Avatar
Durr727
I have a stick and around 4th gear at like 2500rpms is when the car really goes when i step on it.
Old Dec 20, 2006 | 11:13 PM
Reikat's Avatar
Reikat
ofcoarse you have to realize you have to realize that it's a four speed... the gears can be wound out much logner... where as in a manual 5 speed with a powerfull engine,it may be low third... but in like a small car 45 would be almost 5th gear.... it's all about the gear ratio...
But it should be fine in second at 40 ish... it will rev it high... but it will give you the pick up you want... just not too much... these cars arn't ricers they can't be reved high... they are made to be driven with some skill...
Old Dec 20, 2006 | 11:37 PM
Florida_v6's Avatar
Florida_v6
Yeah, to add to what he said I almost never rev mine past 4.5k
Old Dec 20, 2006 | 11:51 PM
tims 88 4's Avatar
tims 88 4
it could be the tccis still in lockup modebut dont quote me on that
