Engine knocking terribly
Old Dec 21, 2006 | 01:50 AM
warheed's Avatar
warheed
Default Engine knocking terribly
My stang has about 181k miles on it, somewhere within the last500 miles it has aquired a terrible knocking sound. This sound started out soft and has gotten louder of course. It also gets worse as the engine warms up more. At first I suspected it was maybe a trashed bearing in my crankshaft, but I had a friend (semi mechanic type) look at it today. He seems to think it's one of my pistons banging against another bearing. Of course the sound increases in speed as the rpms get higher. I know this is a fairly open ended question, thanks in part to my lack of knowledge of the in-depth workings of an engine itself. Anyway, just wondering if anyone else has had this problem, and what you did about it. All relative responses appreciated.
Old Dec 21, 2006 | 02:00 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: Engine knocking terribly
Most likely a rod bearing, bent rod, crank bearing, or bad main. Knocks usually only come from the bottom end.
Ryan
Old Dec 21, 2006 | 02:13 AM
cobra232's Avatar
cobra232
Rod bearing
alittle advise don't trust your mechanic friend because there is no way a piston can bang against a bearing.
it's a rod bearing for sure. i would lay $500 on it.
look around for a 97+ F-150 engine in a junkyard it a 4.2L and will give a nice little boost in power over the 3.8 and the only thing you have to change is use the 4.2L flywheel and put your mustanf upper intake/injector rail and T-body on the 4.2
the 4.2 in a nice torquey engine and can be scored and installed for less than rebuilding your current engine which it really needs badly
Old Dec 21, 2006 | 02:18 AM
jthorn9's Avatar
jthorn9
The Godfather
ORIGINAL: cobra232
Rod bearing
That's the best advice I've heard all day. But yea, cobra232 pretty much sumed it up. If it's not a rod bearing, I'd be highly suprised.
Old Dec 21, 2006 | 01:46 PM
warheed's Avatar
warheed
thanks for the help!
McLeary
Mar 14, 2016 07:50 PM
ctgreddy
Sep 20, 2015 08:35 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Jose Corretjer
Sep 8, 2015 06:32 AM
