engine problems
Old Dec 27, 2006 | 12:04 AM
x9Mustang9x's Avatar
x9Mustang9x
Default engine problems
Most of the time when i start my engine, before i even put it in drive it sputters and wants to die on me, it will drop to 300 rpm. I try to rev it up, but it wont let me, it just sputters and feels dead. Then when i put it in drive or reverse it has a mind of it own and even on the brake, drives lol... any ideas whats causing such a rough idle/start?
Old Dec 27, 2006 | 04:09 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: engine problems
Check your fuel system first, then go with ignition system, then move on to sensors. Check your fuel filter.
Ryan
Old Dec 27, 2006 | 07:11 AM
x9Mustang9x
where/how do i check all this stuff?
Old Dec 27, 2006 | 07:43 AM
xX98StallionXx's Avatar
xX98StallionXx
Well, first, what were you doing before any of this happened anything out of the ordinary? did you run it hard? did you go over a bump at afaster pace? or did it just happen?
Old Dec 27, 2006 | 05:31 PM
x9Mustang9x
no.. just out of nowhere, it doesnt do it all the time just 70% of the time probably
Old Dec 27, 2006 | 06:50 PM
RyansQuick6
Reverse Gear Member
Go pick up a Haynes or a Chilton's manual at your nearest parts store. It will become your best friend. Well worth the $15. I learned more about vehicles reading those books than pretty much anything else. It will walk you trough waaaaaay better than I could over the net. it has pics and everything. You'll also need to pick up a ford fuel line release tool while you're there. Just tell the guys at the counter what you're looking for, and if they're not asses tehn you'll be set.
Ryan
Old Dec 27, 2006 | 07:05 PM
deezelnut's Avatar
deezelnut
I ♥ Acer
check the Idle Air Controller. it is on back of the throttle body.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
