Porting
Old Dec 27, 2006 | 03:12 AM
NvRdoNeStAnGsIx's Avatar
NvRdoNeStAnGsIx
Default Porting
What all do you port? Upper/Lower Intake and Cam shaft?
Old Dec 27, 2006 | 03:16 AM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: Porting
You port the upper/lower intake, and the heads. You can have the cam reground, or just buy one already done.
Old Dec 27, 2006 | 03:19 AM
Jugador's Avatar
Jugador
Default RE: Porting
good luck porting the cam...where did you hear about that?
intakes, cylinder heads, throttle body. i wouldn't port the tb behind the throttle plate. gains from porting the tb are not going to be very noticable, but i just thought it'd throw it in there since it can be done
Old Dec 27, 2006 | 03:25 AM
Clif Brohn's Avatar
Clif Brohn
Default RE: Porting
ORIGINAL: Jugador
Ive never heard of "re-grinding" a cam. Ive heard of new lobes on a cam shaft, or just a new grind of cam to swap out
Its better to buy a large TB(say 70mm) and then match the intake to the TB, porting the TB is better for track oriented cars where every little bit can be done to make the car faster.
Old Dec 27, 2006 | 03:32 AM
Jugador's Avatar
Jugador
Default RE: Porting
personally i wouldnt even mess with it unless the car was built or blown, but if you dont have much cash and can find a free/cheap stock tb it could be worth your time. might do as much as a cheapie cai or a muffler anyway
Old Dec 27, 2006 | 04:22 AM
Flake6899's Avatar
Flake6899
Default RE: Porting
How much hp does port/polishing your intake give you?
Old Dec 27, 2006 | 04:25 AM
MACHJUAN's Avatar
MACHJUAN
Default RE: Porting
upper and lower about 8-10rwhp
Old Dec 27, 2006 | 05:14 AM
Flake6899's Avatar
Flake6899
Default RE: Porting
How bout the cost?
Old Dec 27, 2006 | 05:53 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: Porting
Well genereally when you port and polish heads, you also increase the size of the valves, and the cam aids that by letting them stay open longer. Porting an intake is best left to a pro, because the best way to do it is to cut it in half, port all of it and then cleanly weld it back together. SuperSix does it, just go their site and check otu the prices.
Ryan
Old Dec 27, 2006 | 09:00 AM
deezelnut's Avatar
deezelnut
I ♥ Acer
Default RE: Porting
ORIGINAL: RyansQuick6
Ryan
that's true. a stage 3 powerpak got me around 30 rwhp. good investment.
