Grille Horse
Old Dec 28, 2006 | 07:29 PM
wiksta's Avatar
wiksta
Default Grille Horse
How can i have just the horse in the grille like i have been seeing. Can i do it from the stock grille or do i have to buy an aftermarket one and from where if i do?
Old Dec 28, 2006 | 07:30 PM
fallfast90's Avatar
fallfast90
Default RE: Grille Horse
You have to buy a grill delete kit. Get the 3-piece kit.
www.americanmuscle.com
Old Dec 28, 2006 | 07:32 PM
Durr727's Avatar
Durr727
You have to buy the kit, the Mach 1 Grille Delete.
You can get a good one on eBay, make sure it is the 3 piece though.
And if you would like to change the horse in the middle hit up http://www.autobadges.com
Old Dec 28, 2006 | 07:34 PM
Durr727's Avatar
Durr727
Here is a write up on how to install the kit.
Mach 1 Grille Delete Instructions
Tools required:
* Phillips Screw Driver
* 7mm Socket
* Ratchet
Removing the stock grille from the car:
First, you need to remove the 4 retaining screws on the top of the factory grille, as well as removing the two retaining screws that hold down the stock fascia. This is fairly simple to do, but take your time, as you do not want to scratch your paint.
Next, tilt the factory corral forward just enough so you can get to the four 7mm bolts that hold the factory corral grille at the bottom.
Congrats, you are now halfway done!
Installing the Three Piece Mach 1 Grille Delete Kit:
Take the backing piece (the one with the two circular holes) and install that using the two plastic retainers in the lower corners of the delete kit. Next, take the bottom lip of the delete kit and insert the two plastic retainers into the top of the fascia. Line up the four studs at the base and place them into the factory drilled holes in the bumper and secure them with fascia tabs. Finally, take the pony and mount it into the rear bracket using two screws. We suggest going to your local Ford dealer and getting a set of factory security torx bit screws so that your pony cannot be stolen off of your car.
Old Dec 29, 2006 | 12:52 AM
v6stang07's Avatar
v6stang07
grill delete 3 piece or just paint the chrome corral ring black to match the grill for the delete effect.
Old Dec 29, 2006 | 01:05 AM
johnt2k7's Avatar
johnt2k7
what is the differance in the 2 and 3 piece kits
Old Dec 29, 2006 | 01:09 AM
Durr727's Avatar
Durr727
quality
Old Dec 29, 2006 | 01:17 AM
johnt2k7's Avatar
johnt2k7
what do u mean by quality what is the real differance i didnt know their was a 2 or 3 piece i thought it was just a kit same thing just different companys that made them
Old Dec 29, 2006 | 02:32 AM
amrcnidyot's Avatar
amrcnidyot
the differenece isnt quality...it is 1 piece. the 2 piece comes w/ the horse w/ bracket and the lower piece that covers the hole in the bumper. the 3 piece comes w/ those 2 plus a back plastic piece that cleans it up a lot and it is a true mach 1 kit.
Old Dec 29, 2006 | 02:39 AM
bain_bk's Avatar
bain_bk
the 2 peice come with the pony and the black part that goes under the horse. The kit that has 3 has the 2 and then a part that goes over the silver part that is behind the pony. I got the kit with 2 and i think it looks great.
