Abbreviations
i made a list to help us and the new guys so we dont have to explain what lsd an udp mean uver 5 minutes
232 - Displacement in Cubic inches of 94 to 03 engines
238 - Displacement in Cubic inches of 04 Year engines
245 - displacement in cubic inches of a 05 to current engine
3 Valve - the new 05 to current engines have 3 valves for each cylinder instead of the older one for better performance
3.73's - rear gears , better acceleration over stock gears, street and strip use
3.8 - displacement in liters of 94 to 03 year engines
3.9 - displacement in liters of 04 year engines
4.0 - Displacement in liters of a 05 to current engine
4.10's - rear gears , better acceleration over stock and 3.73, but a little worse MPG , Mostly for strip use not for highway driving
Blow Off Valve - a Valve between the super or turbo charger and the throttle body it is designed so when the throttle body is closed the excess boost will be released instead of breaking something
Bolt Ons - andy minor parts that you can install your self , basic boltons are UDP, CAI, and Exhaust
Boost - the pressure that is created by a turboed or cupercharged car usualy read in PSI
CAI - Cold Air Intake
Cat's - Catalytic Converter
CC plates - Caster camber plates, used to adjust your alignment after you lower the car
DD - Daily Driver
DD - If Talking Bout Tires It means Deep Dish
Drag limited - when using 4.10'S OR 3.73'S you can only reach a top speed of around 130
DTC - Diagnostic Trouble Code
dual exhaust - exhaust that exits on the drivers and passenger side in the rear and uses any midpipe
DYNO - short for Dynomometer measure horsepower and torque of a car
ECU - Engine control unit or computer
F/I - Forced Induction , Turbo , supercharger, or Nitrous
Fox Body - a 79 to 93 mustang or 3rd gen mustang
HP - Horse Power
H Pipe - Mid pipe Shaped like a H
HCI or Power Pack - Head's ,Cam ,Intake Manifold
HID - High Intensidy Discharge lights , you know those bright blue ones that blind you when you are driving
Intercooler - like a radiator that cools the air from the super or turbo charger before it enters the Motor
IRS - Independent Rear Suspension
limp mode - when a check engine light comes on depending on the DTC it may send the car into limp mode which will not allow it to run to its full performance and you will watch ur gas gauge just fall
LSD - Limited Slip Differential
LT - long Tube Headers
M90 - A blower by Eaton that can be modded to fit a V6
M112 - A blower by Eaton that can be modded to fit a V6
MAF - Mass Air Flow Sensor
MIL - Malfunction Indicator Lamp
MIL Eliminators - Used on a exhaust with no cats in place of a rear O2 sensor so the ECU does not through a code and go into limp mode
Mpg - Miles Per Gallon
N/A - Naturally aspirated no turbo ,supercharger, or nitrous all motor
New Edge - a 99 to 04 mustang 4th gen mustang
O/R - Off Road Meaning No Cats
OEM - stock or Origional Equipment
posi - same thing as a Limited Slip Differential
Power Adders - Supercharger ,turbo or Nitrous
PP - port and polish , Grinding the openings in the intake manifold and the heads to allow better airflow to the cylinders
Prochargers - A brand of Supercharger that uses a intercooler
PSI - pounds Per Square Inch
RR - Roller Rocker
S-197 - 05 to current mustang 5th gen mustang
SN-95 - a 94 to 98 mustang 4th mustang
Shorty - Short Tube Headers
Side exit exhaust - exhaust that exits under the doors before the rear tires
single Port - the intake manifold on a 94 to 98
Split Port - the intake manifold on a 99 to 04
sohc - when a cam shaft is over each head of the motor pushing down on the valves instead of the cam mounted under the manifold and using pushrods and rockers like a stock 99 to 04 mustang
SS - stainless Steal
Straight Pipe - When their is no midpipe on the car just a pipe running from the headers to the rear and is usualy run with no cats and sometimes a muffler but not always
Take Offs - stock exhaust taken off of a gt then put on a V6 either with oem mufflers or aftermarket mufflers
TB - Throttle Body
Tlock - A brand of LSD
TQ - Torque measured in Foot Pounds
TruTrac - A brand Of LSD
true dual exhaust - same as dual exhaust but uses a h , or x pipe or Straight pipe but is not true duals if you use a y
TPS - Throttle position sensor
Turn Downs - no pipe after the mufflers just a 90 or a 45 degree turn towards the ground
UDP - Under Drive Pulleys
Vert - Convertible
Vortech - brand of super charger
Wastegate - is used on a turboed carto regulate the pressure in the exhaust line which inturn regulates the boost
X Pipe - Mid pipe Shaped like a X
Y adapter - lets u cut your stock y pipe after the cats and weld in this kit to turn your y pipe into a true dual setup with a H
Y Pipe - Mid pipe shaped like a Y (OEM For a V6)
if any one can think of any i missed let me know
DD - Daily Driver
HP - Horse Power
RR - Roller Rocker
TB - Throttle Body
Vert - Convertible
thats righ it is 94 to 04 isnt it
or was it the same motor in the fox body back in 79
let me know and i will fix the years of the ci and the liters
and were the old fox bodys single port like the sn95's
ORIGINAL: johnt2k7
232 Displacement in Cubic inches of 99 to 04 engines 1994-2003 THANK YOU!!!
238 Displacement in Cubic inches of late model 04 Year engines
245 displacement in cubic inches of a 05 to current engine
3 Valve the new 05 to current engines have 3 valves for each cylinder instead of the older one for better performance
3.73's rear gears , better acceleration over stock gears, street and strip use
3.8 displacement in liters of 99 to 04 year engines 1994-2003 THANK YOU!!!
3.9 displacement in liters of late model 04 year engines
4.0 Displacement in liters of a 05 to current engine
4.10's rear gears , better acceleration over stock and 3.73, but a little worse MPG , Mostly for strip use not for highway driving
CAI Cold Air Intake
Cat's Catalytic Converter
DD Daily Driver
Drag limited when using 4.10'S OR 3.73'S you can only reach a top speed of around 130
DTC Diagnostic Trouble Code
dual exhaust exhaust that exits on the drivers and passenger side in the rear and uses any midpipe Its called TRUE DUAL EXHAUST
ECU Engine control unit or computer
F/I Forced Induction like super or turbo charger or NITROUS
Fox Body a 79 to 93 mustang or 3rd gen mustang
H Pipe Mid pipe Shaped like a H
HCI or Power Pack Head's ,Cam ,Intake Manifold
IRS Independent Rear Suspension
limp mode when a check engine light comes on depending on the DTC it may send the car into limp mode which will not allow it to run to full performance and you will watch ur gas gauge just fall
LSD Limited Slip Differential
LT Long Tube Headers
M90 A blower by Eaton that can be modded to fit a V6
M112 A blower by Eaton that can be modded to fit a V6
MAF Mass Air Flow Sensor
MIL Malfunction Indicator Lamp
MIL Eliminators Used on a exhaust with no cats in place of a rear O2 sensor so the ECU does not through a code and go into limp mode
Mpg Miles Per Gallon
N/A Naturally aspirated no turbo or super charger or nitrous
New Edge a 99 to 04 mustang 4th gen mustang
O/R Off Road Meaning No Cats
OEM stock or
posi same thing as a Limited Slip Differential
PP Port and Polish for newbies this needs more defining like WHAT is done
Prochargers A brand of Supercharger
RR Roller Rocker
S-197 05 to current mustang 5th gen mustang
SN-95 a 94 to 98 mustang 4th mustang
Shorty Short Tube Headers
Side exit exhaust exhaust that exits under the doors before the rear tires
single Port the intake manifold on a 94 to 98
Split Port the intake manifold on a 95 to 04
sohc when a cam shaft is over each head of the motor pushing down on the valves instead of the cam mounted under the manifold and using pushrods and rockers like a stock 99 to 04 mustang
SS Stainless Steal
Take Offs stock exhaust taken off of a gt then put on a V6 either with oem mufflers or aftermarket mufflers
TB Throttle Body
Tlock A brand of LSD
TruTrac A brand Of LSD
true dual exhaust same as dual exhaust but uses a h or x pipe not a y pipe no bc it can use a midpipe as long as its INDIVIDUAL pipes running to the back
TPS Throttle position sensor
Turn Downs no pipe after the mufflers just a 90 or a 45 degree turn towards the ground
UDP Under Drive Pulleys
Vert Convertible
X Pipe Mid pipe Shaped like a X
y adapter lets u cut your stock y pipe after the cats and weld in this kit to turn your y pipe into a true dual setup with a H
Y Pipe Mid pipe shaped like a Y (OEM For a V6)
CAI Cold Air Intake
DD Daily Driver
OEM stock or
RR Roller Rocker
SS Stainless Steal
TB Throttle Body
Vert Convertible
and STFUNIYDKFE (shut the **** up newbie if you don't know from experience) lmfao
but nitrous is not a means of forced induction
forced induction means forcing air into the cylinders
and nitrous does not do that
i can add nitrous in their just not under F/I or N/A
