Audio?
Old Jan 1, 2007 | 03:15 PM
Trigg's Avatar
Trigg
Default Audio?
I posted this in the Audio section but like zero replys so I was hoping some of yall could help me
ok so im tryin to redue my whole audio system, iv got my headunit and subs now my problem is amps and door speakers
Head-Unit: [/color]http://www.sonicelectronix.com/pictures.php?id=6917[/color]
[*]Peak Power Output:[/color]50 watts x 4 chan.
[/align][*]RMS Power Output:20 watts x 4 chan.
[/align][*]Preamp/RCA Outputs:3 Pair - Front, Rear, Sub
[/align][*][color=#3f59a4]Preamp Voltage:[/font][/font]2.5 volts
Subs:2 12"EclipseSW8200[*]RMS power handling: 670W[*]Max. power handling: 2000W[*][font=arial]12" Subwoofer[*][font=arial]Single 4 Ohm
Now my problem is what kind of door speakers should i get? Size? Watt?
Id like to get eclipse brand.
I guess the harder of them all what kind/type of amp should i get?Im gonna have 2 12" Eclipse SW8200 subs in the trunk sothats 1350 RMS Watts.I have no clue about what RMS means and what watt is needed for each speaker or what the Ohm's r. completely ignorant on this part. Specifics would be great. Thanks guys
Old Jan 1, 2007 | 03:25 PM
Stang562's Avatar
Stang562
Default RE: Audio?
RMS are how much it could put out continously for a long time that is recomended by the manufacturer,while max is how much it could put out in one quick moment. As for what brand of speaker, what is your budget?
Old Jan 1, 2007 | 03:30 PM
x9Mustang9x's Avatar
x9Mustang9x
Default RE: Audio?
Door speakers: Pioneer TS-A6871R (Bestbuy, Circuit city, Walmart) 60 bucks at walmart for the pair and they sound great!
Amp: Go for Kenwood or pioneer, cuz they are the ****tt imo youre gonna want about 2000 watts max 1400 rms.... just try to match the max and rms up between the subs and amp the best you can
Old Jan 1, 2007 | 03:55 PM
Trigg's Avatar
Trigg
Default RE: Audio?
well i cant say there isnt a budget because there is, but im willing to spend 2-3 grand to get it done, ill jsut by the pieces at a time if there farely expensive.
brand, id like to keep the whole system eclipse audio. but i know my head unit isnt eclipse. so i guess door speakers: eclipse and amps god only knows, just not legacy or mtx. thanks
Old Jan 1, 2007 | 03:57 PM
x9Mustang9x
Default RE: Audio?
picky picky picky lol jk
so what exactly are you wanting to know then? if you already know what youre getting what are you asking
Old Jan 1, 2007 | 04:01 PM
Trigg's Avatar
Trigg
Default RE: Audio?
i dont under stand the amps part? should i run a amp for each sub? wil my head unitbe able to keep up with the subs and power the door speakers?
I can buy the products it getting them to work together that iv always seem to had a problem with.
o ya whats the size of the door speakers and the sound bar in the rear? i wanna say 5 1/4?
Old Jan 1, 2007 | 04:05 PM
x9Mustang9x
Default RE: Audio?
your speakers are all 6x8s
as for the amp... get a 2000 max, 1500rms(or something similar)amp running to both subs... no need to run 2 amps
Old Jan 1, 2007 | 04:08 PM
x9Mustang9x
Default RE: Audio?
the amp doesnt take power from your stereo, the stereo will push the speakers just fine.... it takes it directly from your battery, the only thing that the amp connects to the stereo is the system control or rem (name depends on the brand), and the rca's... pushing that much power tho youre gonna need a capacitor so it doesnt drain your battery...otherwise your headlights and **** are gonna flicker with the bass cuz it draws so much power out of the battery
Old Jan 1, 2007 | 04:10 PM
Trigg's Avatar
Trigg
Default RE: Audio?
thanks for your help. so about $500 would probably take care of my amp problem then?
Old Jan 1, 2007 | 04:13 PM
x9Mustang9x
Default RE: Audio?
it should, depending on the brand and where you get it
