Lowering the car
Old Jan 1, 2007 | 06:45 PM
mustang232's Avatar
mustang232
Default RE: Lowering the car
can you cut your stock springs to lower the car?? please dont shout at me. im just poor. lol. i would need 1inchoff front & 2 off the rear. or can you cut aftermarket lowing springs if they are not low enough for you? like get 1 inch kit & cut half an inch off before you install them???
Old Jan 1, 2007 | 06:48 PM
jthorn9's Avatar
jthorn9
The Godfather
Yes, you can cut the stock springs, but you also have to modify the shocks, which I'm not too sure about exactly how you do it.
Ebach pro kit for the win.
Old Jan 1, 2007 | 07:27 PM
Chr1s46536's Avatar
Chr1s46536
how much does it usually run for a shop to install new springs
Old Jan 1, 2007 | 07:31 PM
flash20's Avatar
flash20
ORIGINAL: Chr1s46536
i got mine installed for 80 bucks from redv6pony's dad, another shop wanted to charge me 200 bucks[&:]
Old Jan 1, 2007 | 08:35 PM
Durr727's Avatar
Durr727
ORIGINAL: flash20
That's actually fairly resonable. Two shopsI got quoted on were $299 and $349. [&:][8D]
Old Jan 1, 2007 | 08:36 PM
brettxw's Avatar
brettxw
Ya could you post up pictures??
What exactly do the caster plates do?
Old Jan 1, 2007 | 08:38 PM
brettxw's Avatar
brettxw
Are these good? They're a cheap price, if you guys say they are ok then Im gonna order them up
http://cgi.ebay.com/ebaymotors/99-04...67517494QQrdZ1
Old Jan 1, 2007 | 09:43 PM
Chr1s46536's Avatar
Chr1s46536
Since everyone is talking about needing CC plates and that your shocks/struts will go bad, If you got springs that lowered a little less like Roush springs instead of the eibachs so that you wouldnt need the plates, would that help with your shocks and struts not wearing out?
Old Jan 1, 2007 | 10:01 PM
Durr727's Avatar
Durr727
Irecommend you should get C/C plates with any lowering springs purchase.
Lowering the car will put unessecary stress and parts and it will save valuable suspension parts that will cost much more than the $150-$200 that caster camber plates will cost.
Even though you may not need them, you should get them.
Old Jan 2, 2007 | 02:55 AM
amrcnidyot's Avatar
amrcnidyot
most of the kits talked about are lowering it about 1.5". the roush does the same. my passenger side allignment was off a LOT after i put in roush springs. some how the driverside was in speckand it wasnt great but pretty damn good. i bough the camber bolts from stang suspension and had the shop that mounted my tires put the bolts in. they only used one of the bolts(passenger side). now everything is perfect. the bolts were $30. the alignment using my bolts was another 30. thats a lot cheaper than cc plates.
