front wheels bigger then the rear
Old Jan 4, 2007 | 12:20 AM
ryan99's Avatar
ryan99
Default front wheels bigger then the rear
hi
i went today to change the tires on my 99 mustang and they put the bigger wheels in the front and the smaller wheels in the back and im pretty shure the ones in the back are wider (smaller and wider)
its kind of ****t up i dont know if it shuld be like that ...
i need you guys to tell execlly how it needs to be and if its that bad that it came out like that ...
thank you
Old Jan 4, 2007 | 12:23 AM
ByPopularDemand's Avatar
ByPopularDemand
Default RE: front wheels bigger then the rear
I have no idea what you just said, but the wider tires should be on the back...and what do you mean smaller
Old Jan 4, 2007 | 12:25 AM
gt96stang's Avatar
gt96stang
What? you have 2 different size rims? like 17's and 18's?
I need to see a pic of this.
Old Jan 4, 2007 | 12:31 AM
cobra232's Avatar
cobra232
ORIGINAL: ByPopularDemand
no wider tires shouldn't even be on the back. wider tires on the back makes no sense whatsoever. it doesn't handle as good as all four corners the same size and you cant rotate correctly
Old Jan 4, 2007 | 12:33 AM
Durr727's Avatar
Durr727
are there 2 threads of the same thing cause i swear i posted in this and i dont see my post..
Old Jan 4, 2007 | 12:36 AM
ryan99's Avatar
ryan99
the rims are the same size but the tires are a little bit bigger in the front ...
the smaller ones (2) are wider and theyre in the back ...
shuld i put the bigger and less wider ones in the back ?
Old Jan 4, 2007 | 12:37 AM
Durr727's Avatar
Durr727
...just make them all the same size.....
Old Jan 4, 2007 | 12:39 AM
amrcnidyot's Avatar
amrcnidyot
go out to your car and write down the number..such as 245/45/17 or whatever is on the tires and post what each tire is and where it is located.
Old Jan 4, 2007 | 12:47 AM
HornyHornyHippo's Avatar
HornyHornyHippo
I dunno, i just feel cool when i tell people my back are wider haha. That and i looove how the back tires stick out the side bottom of the car when ya look at it from the back, it looks so sick.
Old Jan 4, 2007 | 12:56 AM
ryan99's Avatar
ryan99
ok
front 205/65/5
back205/60/5
