service engine soon
Old Jan 4, 2007 | 07:09 PM
eddiev22's Avatar
eddiev22
Default service engine soon
check engine light came up recently,checked my oil, was very low, changed it just now and started my char and still has the light on... any thoughts ? never had any problems with the car.
Old Jan 4, 2007 | 07:32 PM
Daytripper540's Avatar
Daytripper540
Default RE: service engine soon
You have to have it turned off with a programmer. Or, you can disconnect the battery and then reconnect it and see if it still turns on. If it still turns on that means the oil wasn't the problem.
Old Jan 4, 2007 | 08:43 PM
03YellowPony's Avatar
03YellowPony
Go to Pepboys, AutoZone, CSK, etc and have them pull the code. Then if it was just for low oil(which I really doubt), then you will need to have it reset. Gone are the days of just disconnecting the battery for 30 seconds to reset the light.
Old Jan 4, 2007 | 09:45 PM
Jugador's Avatar
Jugador
but if it doesn't come on again after he resets it wouldn't that mean it was the oil and he didn't have to make a trip to get his car scanned?
Old Jan 5, 2007 | 01:18 AM
Whitecomet25's Avatar
Whitecomet25
Go to Autozone .. my check engie light came on because my coolant temp was too low and my tps sensor was messed up.
Old Jan 5, 2007 | 02:07 AM
ByPopularDemand's Avatar
ByPopularDemand
ORIGINAL: 03YellowPony
If you fix the problem then re-connect the battery how could the computer sense a problem
Old Jan 5, 2007 | 04:46 PM
ecuadorspimp's Avatar
ecuadorspimp
yeah get the code and these guys usually know every code. so post it when u find out
Old Jan 7, 2007 | 02:39 PM
eddiev22's Avatar
eddiev22
the code is P0 456, evap or something, now when i drive i can smell gas... wtf?
Old Jan 7, 2007 | 03:54 PM
amrcnidyot's Avatar
amrcnidyot
it has somethin to do w/ your emissions system. not sure what that code is though. you sure its 456?
Old Jan 7, 2007 | 04:19 PM
Baron von Munchausen's Avatar
ORIGINAL: eddiev22
P0456 = Evaporative Emission Control System (very small leak detected)
The source of the fuel odor may be either in the vicinity of the fuel filler pipe or the evaporative emissions cannister.
