Check engine light
Ok so It came on showingtelling me my o2 sensors were bad...no problem I just replaced them. The computer is now showing P0153- 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)...What could be the cause of this, or do I just need to reset it
That code generally means an o2 failure, but yes it may be a leftover code, I'd reset it and you'll probably need to drive it for a while to make sure it's ok, about 30-45 minutes, taht way it will heat up well.
Ryan
Ryan
