need advice
ok everyone on here keeps talking about all of these upgrades that i dont fully understand but would like to
1. T-Loc / Detroit
2. Gears
3. why is D2D shifting better than 1,2, D on an auto and please explain the concept and how to D2D shift
ok i guess thats all for right now but what do these do and is the T-Loc for manual or auto? thanks i know i feel stupid for asking this but if i dont ask how will i learn
1. T-Loc / Detroit
2. Gears
just another quick question, i just got new wheels and tires i am about to put on do i need a tuner since the tires are larger went from
205/65/R15 to 245/45/ZR17 in the front
205/65/R15 to275/40/R17in the rear
1. fixes the one wheel burnout and gives better traction
2. dont know how to realy explain it but it gives u more lower end power because of the gear ratio which means better torque off the line and quicker acceleration and better 1/4 mile times
3. i dont know how to do it i never understood and couldnt tell the difference i think i was doingit wrong but i was told it makes the shifts firmer and can actualy make the tires chirp or break loose when shifting
4.10s makes your car rev faster, so at 80 mph you will be at 3000 rpm rather then 2500 or whatever it is stock, you loose 2 mpg on the highway - for both autos and 5 speeds
a true trac or trash lok is a limited slip, it transfers power to both wheels evenly under acceleration
for the D2D, about 300 rpms before the redline pull the shifter back from drive to the 2 spot, this is like a built in shift kit, shift lasts less then half a second and is firm, can be done anywhere in the RPM band however to firm shifts (i do it around 4300 and can paint a 2-4 foot strip under right conditions)
Omgitsa88Stang
Oct 5, 2015 07:33 AM
