What should i get?
I have a 99 Mustang. i already have a CAI and an upgraded chip. I was debating on getting detroit tru trac or a T- lock. Any suggestions on exhaust. Magnaflow, Flowmaster??? What is the best brand for UD pulleys?
Magnaflow and flows seem to be the most popular and everyone claims flows sound kind of raspy up top. I dunno myself, since im not doing exhaust...anyway, I recomend the UDP from RPM outlet. For 200 bucks you can get the crank pulley, water pump pulley and belt.
For the LSD it depends on how much power you plan on putting out. If you plan on going much higher than like 220rwhp (everyone agree this is a good number?) then save yourself a few hunderd bucks and go for the T-lok. You have like 165-170rwhp now, so you got a good 50hp to get to the T-lok's breaking point.
Oh, and if you're doing an LSD, get gears at the same time and save yourself some time and money. No sense on taking the rear end apart, installing the LSD, then taking it apart 2 or 3 months later to install the gears.
Well if you "KNOW" you're gonna be running massive loads of power (250-300 rwhp +) on your car, then you better look at the Detroit, if you're just doing a basic quick fix to satisfy your current urges, then the T-lok will do just fine.
Magnaflows for the win, Flowmasters can't even compare.
My sig has all you need pulley wise.
