200HP
Old Jan 21, 2007 | 11:10 PM
98Ga's Avatar
98Ga
Default 200HP
what will i need to get to 200 hp? right now all i have is a cai. would udp, dual exhaust, and a cam give me 200?
Old Jan 21, 2007 | 11:15 PM
mustangman02232's Avatar
mustangman02232
Default RE: 200HP
on a 98? an m90 swap
Old Jan 22, 2007 | 01:01 AM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: 200HP
A 98 is much harder to get 200 rwhp out of but here are a few good paths.
1.) N2O, the cheapest and quickest way to get to 200, in fact, you could go all the way up to 270 rwhp on a maximum 150 rwhpshot.
2.) M-90 superchager, cam, fuel injectors, 90mm MAF, fuel pressure regulator, fuel pump, light port work, will get you there
3.) Split port intake swap, cam, full port job on the intake, 65 or 70mm TB, 90mm MAF, fuel injectors, fuel pressure regulator, fuel pump will get you there
4.) 9 psi vortech supercharger kit, fuel pump, fuel pressure regulator, light port work, 56mm TB will put you there
Old Jan 22, 2007 | 01:03 AM
Xemeth's Avatar
Xemeth
Default RE: 200HP
Well, seeming you only have 150 CRANK horsepower, those bolt ons you mentioned won't do it. It won't even do it for a split port, actually.
Old Jan 22, 2007 | 05:27 PM
98Ga's Avatar
98Ga
Default RE: 200HP
i thougth a supercharger by itself would give me 200hp? which one is the cheapest? it takesa lot to get 50 hp i didnt relize that
Old Jan 22, 2007 | 05:29 PM
fallfast90's Avatar
fallfast90
Default RE: 200HP
Easiest and quickest way will be Nitrous, hands down.
Old Jan 22, 2007 | 05:33 PM
98Ga's Avatar
98Ga
Default RE: 200HP
other than nitrous i dont consider that true hp.
Old Jan 22, 2007 | 05:36 PM
fallfast90's Avatar
fallfast90
Default RE: 200HP
I would prefer some type of F/I or N/A myself, but you asked for the cheapest.
Old Jan 22, 2007 | 06:01 PM
98Ga's Avatar
98Ga
Default RE: 200HP
ok other than nitrous and supercharger,Split port intake swap, cam, full port job on the intake, 65 or 70mm TB, 90mm MAF, fuel injectors, fuel pressure regulator, fuel pump will get you there. how much will all of this cost?
Old Jan 22, 2007 | 06:04 PM
amrcnidyot's Avatar
amrcnidyot
Default RE: 200HP
ORIGINAL: 98Ga
well it is true hp. you could do a dyno to prove it. but i think i know where your commin from. i wouldnt want to put nitrous on mycar either. i would rather have constant hp instead of a little shot at a time.
