engine dyno?
Old Jan 22, 2007 | 07:04 PM
4.0stang's Avatar
4.0stang
Default engine dyno?
This mayor may not bea stupid question but I am going to ask anyway. Is there any way AT ALL to measure engine hp (like an engine dyno) without physically taking the engine out of a car?
Old Jan 22, 2007 | 07:09 PM
fallfast90's Avatar
fallfast90
Default RE: engine dyno?
I am guessing if you take it ata dyno and get the RWHP, they will be able to figure how much you are making at the crank.
98Ga's Avatar
98Ga
yes.
Old Jan 22, 2007 | 07:13 PM
miamiman23's Avatar
miamiman23
http://www.gtechpro.com/theyre ya go, im not sure how accurate it is tho
4.0stang's Avatar
4.0stang
Would that be an exact # or an estimate though?
Old Jan 22, 2007 | 07:40 PM
nanaki's Avatar
nanaki
Retired MF Moderator
RWHP / .85 (15% drivetrain loss) = engine HP
Old Jan 22, 2007 | 07:55 PM
deezelnut's Avatar
deezelnut
I ♥ Acer
ORIGINAL: nanaki
for a manual
RWHP/.80 (20% loss for auto) = engine hp.
Old Jan 22, 2007 | 10:22 PM
cobra232's Avatar
cobra232
first off %loss from drivetrain is not really a good estimate. too many factors to control. clutch slippage or converter wear or burnt fluid or tight wheel bearings.
Chassis dyno's are what you are looking for. you put the whole car on the dyno and the rear tires spin rollers to measure the power to the ground which is the only meaningfull hp measurement.
i have seen many engines dyno big numbers on engine dyno's and only mediocre on a chassis dyno because of a sloppy drivetrain. 40% loss is not uncommon if you have a trans that is not the best but seems fine for everyday driving. a good tight trans and loose wheel bearings can give as little as 8% loss.
you never know unless you dyno the engine then have the car chassis dyno'd.
Old Jan 22, 2007 | 10:29 PM
wolverine_mx's Avatar
wolverine_mx
In addition, i saw on a thread changing the rw pulley for a smaller one (and better design also) will reduce the rwhp loss...
high performance pulleys rulz oncheap engine improvements ha... or a good start for a big one
Old Jan 22, 2007 | 10:54 PM
nanaki's Avatar
nanaki
ORIGINAL: cobra232
for the most part, unless your car has a load of miles on it, or is f/i from the factory, the RWHP divided by .85 will give you a pretty fair estimate. it's not exact, but it's usually damn near close. stock GTs dyno between 220-225RWHP which is almost dead on. stock 99-04 6ers dyno at what? 165RWHP?
