auto v. standard
Old Jan 31, 2007 | 12:39 AM
matts0809's Avatar
matts0809
Default auto v. standard
Performance wise, how much better is a stick shift compared to an automatic???
Old Jan 31, 2007 | 12:40 AM
GregoryA44's Avatar
GregoryA44
Default RE: auto v. standard
auto's are about .2-.3 sec's slower then sticks
Old Jan 31, 2007 | 12:44 AM
silverstang18's Avatar
silverstang18
I ♥ Acer
stick has about 5 rwhp over an auto and you can get a better launch not to mention wine 1st gear higher but once you get into big time performance you can not race a stick you cant switch the gears fast enough.... other than some dam guy with that old blue 5.0 but i think he had a set up where he only had to press in the clutch when he took off my dad tried to explain it i forgot what it was called. so stock you got a little advantage but not much
Old Jan 31, 2007 | 12:48 AM
matts0809's Avatar
matts0809
if i got an auto how should i adjust when it shifts into each gear???
Old Jan 31, 2007 | 12:50 AM
silverstang18
I ♥ Acer
get a shift kit and a tuner.. i have an auto and i like it a lot
03sixbanger has his set up where it chirps going into second in D lol thats crazy........
l_shizzle_l's Avatar
l_shizzle_l
ORIGINAL: silverstang18
umm, i'm pretty sure they have the same rwhp...
Old Jan 31, 2007 | 12:52 AM
matts0809's Avatar
matts0809
what does the shift get do???
Old Jan 31, 2007 | 12:53 AM
silverstang18
I ♥ Acer
nope the stick lays down roughly 5-7 more promise look it up google that ****.... chew it its delicious lol
Dane cook incase you did not know
samseed101's Avatar
samseed101
ORIGINAL: l_shizzle_l
absolutely not. They have the same BHP (at the crank) but the RWHP is less for autos. The torque converter leeches the extra HP away. Of course, you can compnsate and make an auto great to drive anyway (like I did with mine.)
Get a shift kit, get a ratchet shifter, and get a higher stall converter. Then just add HP and TQ and you're good to go.
Old Jan 31, 2007 | 12:56 AM
Clif Brohn's Avatar
Clif Brohn
The advantages a manual transmission has over the auto are the weight(4r70w dwarfs the T5), power(as above stated) and rpms at launch. You cant launch higher than roughly 1600 with a stock auto. Thats the QnD
