cheapest place for longtubes
Old Jan 31, 2007 | 07:15 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: cheapest place for longtubes
I have to concur with most of the people here, MAC LT's are the best thing to get. I got mine pretty cheap since I used to havea MAC account at my old shop.
Get the ceramic coated ones though, it's worth the $100 extra. Keeps the engine bay cooler and holds up better than the paint they normally use.
Ryan
Old Jan 31, 2007 | 07:23 PM
flash20's Avatar
flash20
ok how much hp do they add
Old Jan 31, 2007 | 07:25 PM
SilvrStang's Avatar
SilvrStang
should be in between 10-15 rwhp
Old Jan 31, 2007 | 07:29 PM
flash20's Avatar
flash20
ORIGINAL: SilvrStang
if this is true im happy
Old Jan 31, 2007 | 07:33 PM
SilvrStang's Avatar
SilvrStang
I read this from techs here on forum. Plz correct me if i`m wrong
Old Jan 31, 2007 | 07:46 PM
GregoryA44's Avatar
GregoryA44
im pretty sure thats on gts, stocker headers flow just as good as lt's on sixers
Old Jan 31, 2007 | 07:50 PM
flash20's Avatar
flash20
ORIGINAL: GregoryA44
i hate u ,way to burst my bubble
Old Jan 31, 2007 | 08:02 PM
Verado's Avatar
Verado
Hey... anythings better than stock!
Old Jan 31, 2007 | 08:11 PM
jovez's Avatar
jovez
The shorties flow are just like the stock manifolds. The LT's are better and will result in more gains than the shorties. id say ~7-8 rwhp
Old Jan 31, 2007 | 11:48 PM
BillyBobJoe's Avatar
BillyBobJoe
on GTs, gains are def better. anyway shorties will help also, and they are usually direct fit. from most of the things i've read/heard, LTs will give you a better sound, but not really more performance. If someone wants to give me a dyno graph i'll be glad to say otherwise but i've always heard shorties are for power, LTs for sound. Basically, what happens is with the stock manifolds, the exhaust from the back cylinders are fighthing the exhaust from the front cylinders to get into the manifold causing backpressure, with actual headers, LTs or shorties, each cylinder dumps its exhaust in the same direction at the same place, thus lowering back-pressure.
