question....
Old Feb 9, 2007 | 11:15 PM
crash's Avatar
crash
BrandofPoop
Default question....
imwanting to turbo my 3.8L Mustang..what necessary preparation tuning do i need to do? or what would be smart?
Old Feb 9, 2007 | 11:23 PM
raz54's Avatar
raz54
Default RE: question....
Cooler plugs, new fuel filter, higher rated injectors and a tune.
Old Feb 10, 2007 | 04:31 PM
mustangman02232's Avatar
mustangman02232
tune, upgrade the fuel system, dual exhaust, you should get an LSD
Old Feb 11, 2007 | 03:54 AM
crash's Avatar
crash
BrandofPoop
Default Lsd?
whats an Lsd?
Old Feb 11, 2007 | 04:23 AM
Xemeth's Avatar
Xemeth
Default RE: Lsd?
Limited slip differential. It puts power to both rear wheels, where an open differential (stock V6) has power to one. Hence the "one wheel peel".
Old Feb 11, 2007 | 01:41 PM
dhuskers_11's Avatar
dhuskers_11
Default RE: Lsd?
what would be some good cooler plugs?
Old Feb 11, 2007 | 05:35 PM
laserred38's Avatar
laserred38
Default RE: Lsd?
more research
Old Feb 11, 2007 | 05:42 PM
l_shizzle_l's Avatar
l_shizzle_l
ORIGINAL: mustangman02232
you should notget a dual exhaust, get a bigger single.
why might you ask?
the turbo takes in both exhaust headers to spin the turbine, then puts it out through a single exhause pipe(unless you have an internal wastegate, then you will have 2, but willmerge together6" away from the turbo). you'd pretty much be doing a backwards y pipe if you dual it out, rather than having a single all the way back. and then backpressure will come into play also if you dual it.
Old Feb 11, 2007 | 11:39 PM
crash's Avatar
crash
BrandofPoop
Default tloks?
tloks? thats not a lsd right? r they n e good?
Old Feb 12, 2007 | 03:01 AM
MACHJUAN's Avatar
MACHJUAN
Default RE: tloks?
a t-lok is ok , but if you a turbo route get a detroit true trac that product is more for performace then a t-lok, i have a t-lok and like it but yet im not making much power LOL
