Race time
I have an automatic. what setting should i race in? should i be in OD? put it in regular drive or the other gears? and whats the main difference between them. I know when i put it in D3 it feels way diff than just regular drive.
OD just drops you down a gear then you normally would be in... so ... i would suggest doing it until you get going fast enough... but most races are done by the time it would hurt your engine to leave it off
From other automatics I've driven being in OD didn't matter at all. Once you go WOT it shifts down and you'll never see OD again until you let off the gas or max out the regular gears. Well I don't know about the Fords though.
like i said most races are over in just 3 but if it was a long race then u could max out 3rd adn if your od was on it would shift to 4th instead of using more of 3rd where u have a steeper ratio
carid
Aug 25, 2015 08:17 AM
