Engine hesitation
Old Feb 20, 2007 | 12:16 AM
IECstang's Avatar
IECstang
Default Engine hesitation
This is nuthin major, but i have a 97 stang with exhaust and cai. Whenever i'm going up a hill, if the throttle is in the right spot my car starts to slightly shudder. It's like the transmission is in too high of a gear when i'm going up the hill so it's like the engine is struggling going up the hill. Could anyone help me out here? Thanks
Old Feb 20, 2007 | 12:18 AM
GregoryA44's Avatar
GregoryA44
Default RE: Engine hesitation
check the iac
Old Feb 20, 2007 | 12:20 AM
IECstang's Avatar
IECstang
I'm kind of a newbie so would u explain what that is and how i might go about checking it? I would appreciate it.
Old Feb 20, 2007 | 12:21 AM
v6stang07's Avatar
v6stang07
if ur an aod, u can turn off ur overdrive if this happen and u will drop down to 3rd most likely and will have increased pull up the hill
Old Feb 20, 2007 | 12:23 AM
amrcnidyot's Avatar
amrcnidyot
ORIGINAL: GregoryA44
check the iac
? i doubt that has much to do w/ him goin up a hill.
Old Feb 20, 2007 | 12:26 AM
GregoryA44's Avatar
GregoryA44
always good to check it though
Old Feb 20, 2007 | 12:31 AM
TheMichiganRA's Avatar
TheMichiganRA
Might have something to do with your fuel supply. Try flushing the fuel injectors.
Old Feb 20, 2007 | 12:33 AM
v6stang07's Avatar
v6stang07
the fuel could be a reason, if u have low fuel it could be not pumping as much, i was runnin a little low one night and it had just got cold and up hills my car would stall cause of condensation in the fuel system from the temperature change but if nothin is wrong then turnin off the od will get u up it in a hurry
Old Feb 20, 2007 | 01:34 AM
Xemeth's Avatar
Xemeth
That happened to my old car. I ignored it and ended up destroying a good part of my fuel system (don't remember what exactly, it was a while ago). Needless to say, get it checked out, don't spend over $1000 to fix it like I did.
Old Feb 20, 2007 | 11:09 PM
v6stang07's Avatar
v6stang07
it happend to me like a month ago and it has been fine i just filled up with good gas, added some lucas and went with it, no probs ever since
