Installed UnderDrive Pullies Now I got Problems =\
I finally got my Mac UnderDrive Pulley set (came with the Crank Pulley and Alternator Pulley) on my 96 mustang v6 automatic, but now when I'm idling at night with the headlights on.
I get a drastic reduction in my voltage reading the little gauge actually bounces back and forth.... I have a voltage reader on my Cobra Radar Detector and it reads from 13.5 to as low as 12.3
The voltage will jump back up to 13.8 or higher when I'm driving normally though.
Anyone have any suggestions on how to fix this?
Thanks.
Thanks.
what do you mean idling with the headlights on? what's the problem (i think i might be missing something..) but that's the point of udp: to reduce energy to components on your car and kinda convert it from that to hp. it's like a transfer of power.
I was looking around for something to help with this problem and I ran across this http://www.vmptuning.com/store/index...&parent=51 .
Do you think this would fix the low voltage at idle?
Should I try just switching back the stock Alternator pulley maybe?
Arggg I dunno. [:@]
Arggg I dunno. [:@]
Is it possible to set the Idle Speed higher without using a Tuner?
I was thinking maybe the low idle speed I have (about 600 rpms) could be causing the low voltages, setting it to maybe 800-900 rpms would prolly fix it.
Right or wrong?
Right or wrong?
